SystemD_2kW, any interest for an open design?
...scratching my head, because I am not aware of warning against bridged classD.
Full bridge tells about the hardware, while BTL names a drive pattern.
Common drive patterns of a full bridge are:
- Inverse PWM signal for the opposite halfbridge
- BTL
- Phase shift
- Pulse density
Not a warning against doing it at all; just more options to choose from than for a linear amp, all of which have to do with switching patterns.
I really hate people who think so scary when talking big amps, 2000W-3000W per channel. No man... don't afraid. A 90V supply in bridge class D is very easy to build. And very easy to drive 1500W 8 ohm speaker, or 3000W 4 ohm (2x speaker parallel).
Mine, it has been in service for 2 years without any single mosfet blown. UcD discrete class D.
Just try it, no fear.
Reactions: stewin
High-voltage is not more complicated; just more dangerous. The physics still work the same way. Maybe you're thinking about complexity in terms of keeping people out of it? Or maybe you're confusing/swapping the definitions of complexity and risk?
Switching at low voltage is always easier.
There is more complex on switching at high voltage behavior which at low voltage can be neglected.
No problem you does not agree with me. Practice will tell you more to understand this.
I think its responsible people who deem +/- 90VDC a danger.
Yes it is
But technically it is not as many people think that make an amp at 90Vdc supply is difficult.
My schematic is very simple. Only single level shifter 2SC3503, I have been tried to drive high side floating gate driver discrete at 125Vdc supply easily. At 90Vdc supply it is so safe. It makes schematic so simple.
Yes it is
Hello Kartino
can you share schematic from your discret fullbridge AMP ?
I want try to build
can you share PCB layout or Gerber too ?
please send by email : phoonpool@googlemail.com
two years and the four channel d amp in one casing is still working 😱 very impressive , how about the hissing hf noise ? is it present?
Hishing sometimes yes, not luckily not this amp for some halfbridge model. I am trying reseach to solve. I found some clue that the hissing is leakage frequency from comparator/output back to op amp balanced input. One solution found, by put 100pf bypass cap to R gain of Op amp for balanced input stage.
I just dropped over $1k buying all the components and ordered the pcb's.
Ordered enough parts for 5 boards, amplifier I want to build will use 4, it will be a 4 channel PA amplifier (bridgeable)
Also picked up two hypex SMPS3ka700 power supplies. Got them for a steal from someone in australia who didn't end up going through with a project.
I will keep updating on my progress
Thanks for all your hard work on this Choco, I'm really looking forward to building it!
kindly post photos , it will be nice to see your project
