B1 with Korg Triode
I used Korg as preamp for MoFo and it worked very well with 94 dB speakers. I found out that I played below 1W RMS so Korg was not operating with higher output voltage than intended. I would suggest to try Korg with MoFo without any modification and listen how it sounds and measure output when playing at satisfying level and then make decisions. I may prefer Korg instead of BA-3 pre for MoFo even that "on paper" it is not intended for that.
Having read what's been said and published, it's more likely that trying to run the original circuit at a much higher than design output will add more colour than adding an extra stage.
Yes that's what I thought to. I listen to it now trough the Aleph 1.7 must say the first impression is not good. The first 20 minutes. Trough very cheap loudspeakers to begin with. But they has presented better earlier. Maybe to little gain in Aleph. (350 ohm)
Hi everyone guys,
I received yesterday the two ordered kits and I'm very happy to start my second diy project. The first was an Aleph 3 that I started building ... two years ago ... and I still have to finish 😱... I'd like to ask if anyone has tried the B1 Korg combination with Aleph 3?
Thanks!
Mauro
BIK version 1.5 underway. All wiring and caps removed. Desoldering is SOOO much fun.
Hi everyone guys,
Thanks!
Mauro
I haven't tried the B1K with an Aleph 3, but i am using it with an Aleph 5 - it sounds very very good 🙂
to Leeuwarden
I always have to pay tax and/or handling costs here in Germany if I buy from outside the EU.
I've got a set of LINEAR SYSTEMS JFETs from the DIYAUDIOSTORE today.
JFETs: 39 $
handling costs customs: 6,67 €
and tax: 6,00 € 😱
The state needs money...
Greets
Dirk
