It is ok for a low fi application such as boasting an cell phone output.
R1 makes NO sense unless it is for an electret capsule (naked or in a headset).
At moderate speech levels, a few mV, the THD will be acceptable.
In a hi-fi system, the juice coming out of R1 may annoy the source, and hundreds of mV signal will make it a "fuzz box".
Most time we do not need any "pre-amp", may be;-)
Leave it, unless you want to do disco or be the loudest in the village;-)
Joined 2009
One reason I can think of for wanting an active pre-amp is to use a circuit that makes a linear pot behave like a log pot. Linear pots are known to have far better ch-ch tracking. The only example I'm aware of is the Shindo Claret all-tube pre-amp but I'm sure there are SS examples.
That circuit is designed for low source impedances only, and I believe doesn't go to fully mute.
I agree about the low input impedance. It does look to me as though voltage gain goes to nominally zero, though, when the pot is fully CCW. That setting results in a nominally zero-ohms feedback resistor from output to inverting input.That circuit is designed for low source impedances only, and I believe doesn't go to fully mute.
-Gnobuddy
5 ohms output impedance though, rather the sub-ohm you'd get with a single opamp output amp. That allows a small voltage to be injected at -60dB or so.
Rather than parallel that opamp, its output should have been augmented after the feedback point.
Hello Bimo(Anistardi) and Diy members, I need Gerber file of this simple blameless Pre-amp. If somebody have please Post.
https://www.diyaudio.com/forums/analog-line-level/296144-transistor-preamp-19.html#post4826846
Hello You got Gerber for Blameless Preamplifier ?Thanks Bimo for replying.
Just for Jrp27=late memory rewind, Plz, refer to Andy Collinson's & Graham Maynard's hi fi pre-amplifier circuit _ link= http://www.zen22142.zen.co.uk/Circuits/Audio/hifipreamp.htm.Any good small, easy, high fidelity transistorised preamplifier circuit that i can build ? Plan to use it with my DIY power amp. The preamp should be able to accept ipod level input.
Any help would be appreciated.
2sd30, obsolete unobtainium Japanese metal transistor hyped (net) to be single transistor audiophile preamp?
Did you get those Gerber files,Hello Bimo(Anistardi) and Diy members, I need Gerber file of this simple blameless Pre-amp. If somebody have please Post.
If you got them can you share them here with us
Very neat design.I like Apex designs - they are easy to make, work, and sound good.
BJT:
FET:
More here:
http://www.diyaudio.com/forums/solid-state/164093-100w-ultimate-fidelity-amplifier-6.html
Congratulations to @apexaudio
Impressive for a 70's PreampJames Bongiorno is the designer of Ampzilla and other famous products.
Here is an article he wrote for the June 1972 issue of Popular Electronics, with the modest title
Build a Distortionless Preamplifier
Oops since it is bigger than the max filesize for .pdf here on DIYA, I have extracted each page of the article individually. There are 5 pages and 5 .pdf files attached. Sorry for the annoyance.
Very neat design.
Nothing in the signal path... pretty good eh??? Just 2 gain devices. If I ever become cruel & senseless to insert a preamp in my setup, this will be it.
- Analog Line Level
- Transistor Preamp
