I’m not familiar with that black wima( maybe pps cap) , but the other 2 caps have the same dielectric , same value , just choose the one with the color you like more .
Yeah you are right, black Wima is NOS PPS... I know I'm obsessing but... I kind of like that part of preparing stuff for build 😀
I can not find info on V4H input impedance... Is it 10K as V4?
Yes it is.
Yes it is.
Thanks. I'll shoot some more since you are back 😉
-What is expected power on +-44VDC/Exicon config.?
My pleasure. 😁
About 110W/180W into 8r/4r.
GB Update:
Hi fellows.
We are now moving towards the fourth groupbuy of the V4H Rev1 boards. Please add your entry if you like a pair or more.
Thanks.
shaan
Hi fellows.
Thanks.
shaan
Hi Shaan,
I couldn't find BAV21 at Mouser and got BAV20. Is it OK ?
Hi.
Yes BAV20 will work as well.
The drawings look lovely.
What's the green block in the centre of the front panel, mounted from inside? I presume the two PSU are mounted on two sides of the front panel, right?
How tall is your case?
Thanks! Green is me being lazy to make real 3d of soft start but its useful for showing size. Psu is Cresnet 600W SMPS and the case is MODU Shop 3U - 120mm tall case
Dissipante 3U 300mm 10mm SILVER front panel - 3mm aluminium covers and rear panel
Cheers, Ivica
Cheers, Ivica
Sent you the SMPS-600 STEP file.
Thanks. 🙂 Understood.Thanks! Green is me being lazy to make real 3d of soft start but its useful for showing size. Psu is Cresnet 600W SMPS and the case is MODU Shop 3U - 120mm tall case
Cheers, Ivica
All that empty space makes me wish we were building integrated amps instead of just a power amp. 😀
Hi Shaan, do you have available PCBs? if you do please count me in for a pair V4H GB and one piece of PSU GB please.
One more layout render with real SMPS 3D thanks to Sami/Cresnet.
Looks better now... 😉
- Group Buys
- PeeCeeBee V4H GB
