John Curl's Blowtorch preamplifier part III
Wow - some serious skills their from the Bruns guy and the ancient Chinese stuff as well!
I remember seeing Chinese ivory balls as a six year old at the Sydney museum, my reaction was WTF !......and HTF do they make these things !.
Also Ref. 9 is giving further information about the Chinese puzzle balls. "These detailed works of art are usually made up of at least 3 to 7 layers, but the world’s largest puzzle ball is actually made of 42 concentric balls all enclosed one within the other". And also: "Although the inner balls can be manipulated to align all the holes, Chinese puzzle balls got their name from people who, through the ages, pondered the mystery of making such objects" [9].
Dan
Funny, I "peeked" where I was not supposed to in China and saw a room with CNC machines turning out jade replicas for tourists (ivory is illegal).
It’s called progress Scott!
Reminds of the video I saw about the team that goes around maintaining the Taj Mahal where the guys making replacement tiles still use the ancient technique of an abrasive wire and pedal power plus flywheel to cut the stuff. No lasers or modern electric tools.
My LTspice model implements:
BL(i)
BL(x)
Eddy current BL(e)
coil braking eddies BL(iv)
Steel parts saturation
Surround Kms(x)
Spider Kms(x)
Air resistance Rms(v)
Steel saturation R(i)
But it is messy.
Is it posted up somewhere?
Clearly a huge effort on your part but I’m wondering if it’s not really a job for Mathcad or perhaps something written in Python since you have a huge array of graphics and graphing functions plus some serious math modules.
(My youngest has spent the last 8 months getting to grips with it and is turning out some seriously professional looking stuff already. I on the other hand have just stuck with C++ for embedded stuff - no clue about writing stuff for the PC).
Thanks.
I note third is 20db below fundamental at 30 Hz.
SOTA perhaps, that is prelim info from the write up.
In light of the measurement I just provided, have they ever done an Ls/Rs sweep with the voice coil locked in various positions?
I ask, as a standard solution to Le(x) is the shorting ring added to magnet side excursions to balance out the inductance drop for forward motion decoupling from the magnetic circuit. As I pointed out half a year ago, stabilizing Le(x) in this fashion comes at a cost, that being increasing losses at high frequency during excursion behind the front plate.
I suspect that if they had solved that, there would be a pending patent. So, while it looks good and the write up says all the correct things, I suspect they have not solved that which we have been discussing.
Indeed, they did not provide any two tone IM measurements of the caliber as that you posted back in last discussion. I wonder how they would fare?
Ps. It would also be interesting to determine if any speaker Manu people peruse sites and discussions like ours to advance the cause. I would hope so, even if they are not allowed to state such.
Jn
Bonsai said:
However, back on the ground here in 2019, the relationship between magnetizing current and load current has finally been made clear. As is the fact that the secondary load current does not lag the primary load current component only that it is 180 degrees out of phase with it. It’s the mag current only that lags the source voltage by Pi/2
Thank you for sharing the paper.
Also what I said but was scorned by jn.
No, it is not. Recall you stated the secondary flux cannot be opposite the primary, as it can "use it all up", leaving no magnetizing flux. Then Richard chimed in saying he thought something was amiss in my explanation..
As depicted in the linked paper (figure 2), the secondary flux is opposing the primary, this is as stated in Lenz's law, something you also claimed does not exist.
Both of these statements are forever locked in this thread, you can't remake history (even though you try).
If you had learned transformer theory correctly, you would know that the secondary opposing flux does not "consume" the magnetizing flux. It's existence is the reason the primary draws more in phase current from the source. That is precisely how power is transferred through the core.
What does shock me however, is in this day and age somebody has to actually write a paper that explains transformer action.. sigh, I learned this stuff back in '74 and it was ancient history then...
jn
I've copied your salient statements for review. Not the entire post, just the shall we say, "interesting statements". No intent to misinterpret here, just what you said.
Lenz' law is actually not any law of its own....snip
Interesting to hear that..so would Emil.
The fallacy is to infer that since the ring flux opposes the rate of change of the original flux, it tries to keep the flux constant.....snip
See Lenz's law..
Namely, 'opposing the rate of change' does not oppose or exclude the magnitude at all.snip
It opposes the rate of change. That is Lenz's law, and that is what I stated.
If such a mistaken form of Lenz' law would really be imposed upon us, all transformers would be rendered pretty useless, as their magnetizing flux would be soon eaten up by the load current.
Please learn transformer theory.
And, wait....did you just refer to Lenz's law? You just said it is actually not a law on it's own...
jn
I haven't posted it anywhere and probably won't if I can't clean it up. It's just a mess of behavioral sources and would require significant reverse-engineering to understand it.
I generally agree but if the problem is posed with symbolic equations, when you add any non-linearity there are in general no solutions to the resulting differential equations. You really need FEM or a sparse matrix package which is all SPICE is.
