STEG K4.01
hey perry is the suggestion by Mario a shunt resistor to ground? or Mario please explain the reasoning behind this
Sorry, for my absence, I was on vacation.
K series STEG amplifiers are engineered amplifiers in Italy, for a very long period they were also produced in Italy, then, for cost reasons, the production was moved to China.
They are all managed by a microprocessor which, however, manages only the protections, while the PWM of the power supply and the audio are managed as a very common class AB or D.
For this reason, if there is a problem, this is communicated to the processor which eventually blocks the power supply PWM and communicates the error by flashing the LEDs.
If you take a look at the amplifier user manual, you can find the type of problem by referring to the type of flashing of the LEDs.
Usually your type of problem derives from a ground virtual problem, for this reason the addition of a resistor with a value between 33 and 100R between primary and secondary mass could solve the problem.
In the past it has already happened to me and I solved it this way.
Usually your type of problem derives from a ground virtual problem, for this reason the addition of a resistor with a value between 33 and 100R between primary and secondary ground could solve the problem.
here are the pics requested.
I'm not sure if I understand but if an amp has positive and negative rail voltage, the negative terminal of one bank of rail caps will be at the negative rail voltage. Don't power it up if you have one 330 ohm resistor connected to the negative rail.
Wait for the other forum member who made the suggestion to clarify what you are supposed to do.
I have installed a 33ohm resistor on both sets of rail caps (negative) and attached it to ground. please advise if this is correct. both red and green LEDs are still flashing.
You did not understand.
The resistor should be installed from the center point of those capacitors to the battery ground.
You installed them from + rail and - rail to the battery ground.
Thus you will get a great SHORT CIRCUIT.
