New 12" Full-Range: Fane 12-250TC
That is true, but the rising response in the response from 5K till 12K is too much, and a wide notch filter can tame that a bit. I did build a ported box with this driver for a friend a few weeks ago, and the notch filter does help a lot to tame that. But don't tame it to much (i did +/-4dB off in that passband) as the rising high frequency response is a bit needed in a FR speaker. But this Fane has a too big rise in the high frequency response, and taming it is necesairy. You can do it with speaker cloth, or with a electronic notch filter like described.
My Mark Audio Alpair 10M Gen3 speakers (my main set) has also a slight rise in that section, but it's much less (half that of the Fane) and therefor perfect for the setup and don't need not notch filter at all. I've run that driver for about 4 years without crossover or other electronic correction at all (just the speaker in a ported box straight connected to my amp). Now it's a part of a WAW setup (with an Scanspeak subwoofer tuned at 25Hz and a 1st order serial crossover at 180Hz) as i'm a bass addict and the Alpair 10M gives not the big and defined bass i like... But for most it will be loud and low enough without.
Can you post details about the box and the notch filter that is used?🙂
The boxes are finished. Around 90 l sealed, full of fiberglass. They sound good as expected. Measurements will follow. Still need to test them with the tube amp.
Im thinking to get a pair of these.. but the enclosure design is a big question. I like special enclosures and was thinking how would this work in (ML) tqwt. Qts too high for such? My goal is to get good extension down to 40Hz or so without adding any EQ.
Ported box seems to be out of question. As far as I know, mltqwt should work better with high qts drivers.
220 litres is not that bad actually..if it works well. Heck, I have seen huge dual tqwt's and rear loaded horns having single 6 inch driver!
Sealed indeed would be the most economical choice but its just too typical for my taste. There is no "fun factor" what so ever.. 😀
Very funny.
I was not after extreme bass, then I'd have chosen something else entirely. I had some trouble adjusting for EQ because I had less problems with rising HF response than the datasheet says, and limited opportunity for measurement and building, as this was during my short vacation in Bali. So in case you are referring to the measurements in the beginning of the thread, they where merely prelimenary results.
I had the opportunity to measure the speakers at close to 1/2pi and test the limits of what this driver can do completely by itself, in a relatively compact enclosure, so I did just that.
Look at post #15 and #16, they sounded very neutral and not bass heavy at all. I can see if I can find some videos when I get home if you have any interest of it.
Remember this is halfspace in very noisy surroundings, so in order to get any reasonable noise floor I had to run perhaps 5 sweeps at stupid loud volume to get half decent results, and just choose the ones that wheren't completely ruined by outside-of-my-control noise sources. So in-room it would be a much easier story.
