-snip-
root@arm:/home/debian# systemctl status mpd.service
● mpd.service - Music Player Daemon
Loaded: loaded (/lib/systemd/system/mpd.service; enabled; vendor preset: enab
Active: failed (Result: exit-code) since Fri 2019-08-09 08:05:21 GMT; 17s ago
Docs: man:mpd(1)
man:mpd.conf(5)
file:///usr/share/doc/mpd/user-manual.html
Process: 1199 ExecStart=/usr/bin/mpd --no-daemon $MPDCONF (code=exited, status
Main PID: 1199 (code=exited, status=1/FAILURE)
First of all try this command: systemctl stop mpd.service. Then edit /lib/systemd/system/mpd.service and replace $MPDCONF with /etc/mpd.conf. Then send the command systemctl daemon-reload and restart MPD by systemctl start mpd.service. I hope your problem will be solved.
After some more testing I see all files are "unwritable" 😕, even after sudo su
I tested the following files:
/etc/fstab
/etc/mpd.conf
/boot/uEnv.txt
All are unwritable so somehow something went wrong ... how to restore ?
I use login user=debian password=botic and am still running of the SD card ..
@twluke: /lib/systemd/system/mpd.service is unwritable too ....
PS ... permission problem is solved
After reboor I need to run "sudo mount -o remount,rw /dev/mmcblk0p1 /" again .... I remember there was some instruction how solve this issue ?
/etc/fstab
/etc/mpd.conf
/boot/uEnv.txt
Probably not relevant. If you are using a Cronus board for external MCLKs with proper divider setting on it, leave these lines as they are. If you want to set the divider to 1:1 with 45/49 clocks on the Cronus, you have to select 45/49 line in uEnv.txt; likewise 90/98 line for 90/98 clocks.-snip-
What are the correct steps to set these parameter ?
In /boot/uEnv.txt I see:
cmdline=coherent_pool=1M net.ifnames=0 quiet
#cmdline=coherent_pool=1M quiet snd_soc_botic.clk_44k1=45158400 snd_soc_botic.clk_48k=49152000
#cmdline=coherent_pool=1M quiet snd_soc_botic.clk_44k1=90316800 snd_soc_botic.clk_48k=98304000
Is this related ??
The log file setting is depedent on the setting in your /etc/mpd.conf. Usually in /var/mpd/mpd.log (IIRC).P.S. reading the data above (failed to open log file "/var/log/mpd/) I see the file mpd.log is "unwritable"
-snip-
This read-only problem is probably due to the wrong uuid in /etc/fstab. If you have another bootable linux system other than the Botic system on the BBB, boot into this system (i.e., from eMMC if Botic on the SD slot or vice versa). Then you can mount the device containing Botic system and can edit the /etc/fstab of it.
The command lsblk will tell you which device is available and lsblk -f will tell you the UUID of each device. Choose the correct one and replace the old UUID in /etc/fstab with it by editing. Make sure which device is which. The active device is indicated by / at the end on lsblk.
Example of lsblk -f
Code:
debian@arm:~$ sudo lsblk -f [sudo] password for debian: NAME FSTYPE LABEL UUID MOUNTPOINT mmcblk1 └─mmcblk1p1 ext4 rootfs 960a45c8-51c4-4c7d-83db-3be4131cb750 / mmcblk1boot0 mmcblk1boot1
I solved the permission issues and fixed part of MPD pproblem 🙂
I run I2S direct to a simple ES9023 DAC, no I2C communication and no DSD required.
This would suggest I should have setting I--- instead of MMM:
Where / how can I adjust these settings now ?
root@arm:/home/debian# grep . /sys/module/snd_soc_botic/parameters/*
/sys/module/snd_soc_botic/parameters/blr_ratio:64
/sys/module/snd_soc_botic/parameters/clk_44k1:22579200
/sys/module/snd_soc_botic/parameters/clk_48k:24576000
/sys/module/snd_soc_botic/parameters/dai_format:16385
/sys/module/snd_soc_botic/parameters/dsd_format_switch:1
/sys/module/snd_soc_botic/parameters/ext_masterclk:3
/sys/module/snd_soc_botic/parameters/pinconfig:default
/sys/module/snd_soc_botic/parameters/serconfig:MMMM
The error on MPC and MPD is getting the following result:
root@arm:/home/debian# mpc play
mpd error: Connection refused
Loaded: loaded (/lib/systemd/system/mpd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2019-08-09 09:45:44 GMT; 13min ago
Docs: man:mpd(1)
man:mpd.conf(5)
Process: 1310 ExecStart=/usr/bin/mpd --no-daemon /etc/mpd.conf (code=exited, status=1/FAILURE)
Main PID: 1310 (code=exited, status=1/FAILURE)
Aug 09 09:45:44 arm systemd[1]: Started Music Player Daemon.
Aug 09 09:45:44 arm mpd[1310]: Aug 09 09:45 : exception: Failed to bind to '[::]:6600'
Aug 09 09:45:44 arm mpd[1310]: Aug 09 09:45 : exception: nested: Failed to bind socket: Address already in use
Aug 09 09:45:44 arm systemd[1]: mpd.service: Main process exited, code=exited, status=1/FAILURE
Aug 09 09:45:44 arm systemd[1]: mpd.service: Unit entered failed state.
Aug 09 09:45:44 arm systemd[1]: mpd.service: Failed with result 'exit-code'.
Aug 09 09:45:44 arm systemd[1]: mpd.service: Start request repeated too quickly.
Aug 09 09:45:44 arm systemd[1]: Failed to start Music Player Daemon.
Docs: man:mpd(1)
man:mpd.conf(5)
-snip-
Check the correct location of mpd file by which mpd. The MPD file in my image is located in /usr/local/bin/mpd. If this is the case, again re-edit /lib/systemd/system/mpd.service.
I am ggetting somewhere 😀
I had to run the systemctl commands again (see first lines🙂 ) but what about the "bind to address" error at the bottom ?
root@arm:/home/debian# systemctl enable mpd.service
Synchronizing state of mpd.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mpd
root@arm:/home/debian# systemctl daemon-reload
root@arm:/home/debian# systemctl start mpd.service
volume: n/a repeat: on random: on single: off consume: off
Active: active (running) since Fri 2019-08-09 10:15:12 GMT; 21s ago
Docs: man:mpd(1)
man:mpd.conf(5)
Main PID: 1910 (mpd)
Tasks: 5 (limit: 4915)
CGroup: /system.slice/mpd.service
└─1910 /usr/bin/mpd --no-daemon /etc/mpd.conf
Aug 09 10:15:12 arm systemd[1]: Started Music Player Daemon.
Aug 09 10:15:12 arm mpd[1910]: Aug 09 10:15 : exception: bind to '0.0.0.0:6600' failed (continuing anyway, because binding to '[::]:6600' succeeded): Failed to bind socket: Address already in use
From /etc/mpd.conf:
# For network
bind_to_address "any"
Docs: man:mpd(1)
man:mpd.conf(5)
From /etc/mpd.conf:
# For network
It's quite okay. You can ignore this error.
Rgds,
Thank you very much for your support so far
Because of multiple errors I still wonder about the optargs settings as mentioned earlier:
This would suggest I should have setting I--- instead of MMMM:
Setting I--- will be appropriate. Though I don't know whether your DAC is used as master or slave in terms of MCLK clock setting, I suppose that you are referring to http://bbb.ieero.com/. There is a section of "DAI format", in which I think you can find your appropriate setting.
Rgds,
This I wrote at the bottom of page 284: it explains why I do not understand where to edit these settings now.
From the old Botic I had to mount "/boot/uboot" and edit uEnv.txt" to be able to set the correct optargs parameters.
Is this still neccesary ? ... when I do so the uEnv.txt file is empty but when I do not mount it and edit /boot/uEnv.txt there is a lot in there but no "optargs" line
Is this related ??
Is this related ??
Is this related ??
If your DAC has no onboard clock, the clock on BBB, which is 48K only, becomes MCLK (i.e., 44.1K clock is not supported). Modify the kernel option in uEnv/txt by adding "snd_soc_botic.ext_masterclk=2" just after "cmdline=coherent_pool=1M quiet" and there will be no need to add "snd_soc_botic.clk_blah_blah".
This means 44.1K sources will be played with different rate. The details are well described in the section of "Clocks configuration".
Rgds,
I have 2 Beaglebones for testing.
One with external clock for 44.1 and onboard for 48k which I used so far (Botic 4)
The other has a hacked XMOS USB receiver board from which I re-used the dual clock section which I want to use now 😉
I know what values I have to set for snd_soc_botic options from the Miero page.
I was used to see optargs= ... blabla
Apparently now it is similar options but now I put the options after cmdline=
Hacked: 😀
Hacked: 😀
My earlier question about the socket error I was experiencing at "systemctl status mpd.service" :
From /etc/mpd.conf:
# For network
If I change "any" to "0.0.0.0" (like was mentioned in the first BeagleBone topic at ComputerAudiophile.com - I guess that was in 2013) the error is not shown 🙂
Active: active (running) since Fri 2019-08-09 12:52:40 GMT; 5s ago
Docs: man:mpd(1)
man:mpd.conf(5)
Main PID: 1209 (mpd)
└─1209 /usr/bin/mpd --no-daemon /etc/mpd.conf
Aug 09 12:52:40 arm systemd[1]: Started Music Player Daemon.
From /etc/mpd.conf:
# For network
Rgds,
Docs: man:mpd(1)
man:mpd.conf(5)
Ignore my latest reply above ... It does not give conclusive results so I am not sure what causes the random problems ... need to investigate further
If you are still persistent with this issue, then try this one: systemctl disable mpd.socket. Enabling this socket is the culprit, though I don't care.Ignore my latest reply above ... It does not give conclusive results so I am not sure what causes the random problems ... need to investigate further
Rgds,
I am already past this “error” but still have some other issues but stopped for now.
I was probably naive thinking I solved the “bind-to-address” warning message as I really have limited linux knowledge and mainly do trial-by-error if it gets over my head.
I will try to pinpoint my other issues and report back later.
Debian IMG for BBB
Hi!
Please specify, which DEB packages contain your last Volumio img file and why it is so big?
Mayby it is time to re-release it
Hi!
As the original issue was mpad no longer working, why not use soundirok instead. I needed to do the same change and like soundirok much better. No need to change anything on MPD.
- More Vendors...
- Twisted Pear
- Support for Botic Linux driver
