Amigo please go away.
I know that Americans are generally ruder than people from other countries
Installation of Botic kernel into volumio 1.5BBB
dear miero, dear alle!
any reply to my post
Support for Botic Linux driver
any suggestions how to install the botic kernel into volumio 1.5BBB? unfortunately the botic scripts on the miero website don't work anymore and need to be updated :-(
thanks and regards
thanks and regards
thanks and regards
since wheezy and jessy are not supported anymore and moved to "archive", i think miero has to change some of his files/scripts.
updating "sources.list" according to the new debian "archive" servers seems not to be enough :-(
@ miero: please advice and help!
many thanks
many thanks
update:
changing the sources.list to archive.debian.org did the job! now it seems everything to work fine! 🙂
Maybe a link for RP will help?:
volumio mirror repo * volumio/Build@b04fe63 * GitHub
deb Index of /debian jessie main ui
deb-src Index of /debian jessie main ui
deb http://archive.volumio.org/debian/ jessie main ui
deb-src http://archive.volumio.org/debian/ jessie main ui
The jessie-backports suite was archived on archive.debian.org, so you can use:
deb http://archive.debian.org/debian/ jessie-backports main contrib non-free
deb-src http://archive.debian.org/debian/ jessie-backports main contrib non-free
Using Debian Long Term Support (LTS)
LTS/Using - Debian Wiki
Important: Jessie-LTS only supports i386, amd64, armel and armhf. Users of other architectures are encouraged to upgrade to Debian 9 ("Stretch").
The current LTS version is Debian 8 "Jessie" and will be supported from 2018-06-17 to 2020-06-30. To receive security updates, your /etc/apt/sources.list should look like this one:
deb Index of /debian jessie main contrib non-free
deb-src Index of /debian jessie main contrib non-free
deb Debian -- Security Information jessie/updates main contrib non-free
deb-src Debian -- Security Information jessie/updates main contrib non-free
thanks amigo1, i changed the links in the sources.list to archive.debian.org and it works well.
Debian Buster IOT or Console for Beaglebone Black?
Debian 10 (Buster) - Weekly for Beaglebone Black. Kernel: 4.19.59-ti-r26
Beagleboard:BeagleBoneBlack Debian - eLinux.org
Is the new BB Ai compatible with the Hermes /Cronus cape & the existing images of BBB Botic Linux(Arch/Debian)?
Would the new board be any useful or rather pointless? Anyone already tried?
Great question. The original BBB has too small memory to parse the 13000+ music files on my local SSD, and Volumio software goes to infinite loop.
The AI seems significantly more powerful. Maybe music wise this isn't an advantage, but the original BBB is really under powered.
Seems to be on first glance. Interesting device for sure since it has also Wifi 5ghz onboard which I am missing from my BBBW.
Since it states to be pin compatible with the original BBB it should also work with the BBB-Hermes.
It will not be 100% compatible.Is the new BB Ai compatible with the Hermes /Cronus cape & the existing images of BBB Botic Linux(Arch/Debian)?
I've checked pin mapping possibilities for I2S signals, and it seems that only 3 of 4 data lines will be available after remapping to mcasp1 controller:
P9_25 mcasp1_ahclkx
P9_31 mcasp1_aclkx
P9_29 mcasp1_fsx
P9_30 mcasp1_axr10
P9_41 mcasp1_axr7
P9_42 mcasp1_axr12
P9_27 xxx missing data line on this pin
So purely from a I2S data perspective it MIGHT be possible to update kernel & DTB to be compatible with older Hermes-BBB, at least for stereo I2S mode.
I'm not sure with DSD playback now, because there is a different order of serializers on pins 30 and 41, so it might need additional work in a driver.
Certainly, the physical similarities between BBAi and BBB make the possibilities attractive for continued use of the Hermes/Cronus. However, pure bang/buck of the AM5729 leaves something to be desired IMHO [compared to, for example, the 6 cores on a significantly cheaper Odroid N2]. It would be fun to peek at Brian and Russ's development plans for any new interfaces to the B3 DACs! 😀
BTW, I'm using an Odroid N2 as a server and it is really solid.
I have read that BeagleBone AI overheats after SW Upgrade! Google Groups
https://www.element14.com/community/servlet/JiveServlet/downloadImage/2-282741-772358/photo_BB_AI_Heatsink_1.jpg
Are you use Odroid N2 codec for sound processing and Toslink for sound output?
Nope. Odroid N2 is running 24/7 with server software and Python control code. BBB is managing the I2S and LADSPA filters in ALSA. I am interested in different crossover filtering options and for that, the more CPU the better.
Heat throttling is a fairly common problem among the different SBCs. On the Odroid N2, the SOCs are mounted "on the bottom" against a heat sink that serves as the base for the entire circuit board, so they have better heat dissipation than chip-sized adhesive heatsinks.
For my audio tasks (internet audiostreaming) I need just Volumio +BBB + Spdif hat, but Volumio for BBB is nearly dead and I force to use Debian 10 Buster.
... Volumio for BBB is nearly dead and I force to use Debian 10 Buster.
Can you tell me what are the differences between the Volumio music player and the Debian players? You seems rather unhappy with the Debian, don't you?
I used Volumio and Runeadio till now, so I'm not familiar with Arch/Debian user interface.
- More Vendors...
- Twisted Pear
- Support for Botic Linux driver
