I googled it to check! You think I'm joking?
I know what a sweet spot is and I stay in it.....my wife thinks I’m nutz but she does comply with my living room real estate requests!
Hehe, but do you sit with your head in a vice? This is what it takes to hear the same thing repeatably. In fact this is the only way to do a proper blind test.....
I won’t be coming to your house for any blind testing for sure!
When I’m critically listening I basically do sit motionless and also test off axis.
I recall seeing one back in the 80's.Hehe, but do you sit with your head in a vice? This is what it takes to hear the same thing repeatably. In fact this is the only way to do a proper blind test.....
Yes. One time I thought I was mistaken, but it turned out I was incorrect.Sorry, I should have said repeatably, but you got my point. Have you never thought you saw something but were mistaken?
Couldn't resist..
Jn
Yes, cable insulations sound different and these 'signature sounds' are recordable.Dan, Maybe you have picked up on something of significance here. If the white flex contains titanium dioxide as a colouring agent, then presumably the black flex will more than likely contains carbon. Both carbon and titanium dioxide have electromagnetic properties, and if so, then those properties should be measurable. If they have a subjective effect upon musical playback quality, those said properties will be objectively tunable as per situational requirement.
Some sounds 'play nice' together, others 'play bad' together and this is the basis of 'tuning' as it is practiced.
Titanium oxide is pretty uniform, carbon black is of variable provenance and carbon impurities are cause of bad sound in some black cables.
Dan.
Thank you, and exactly how I call it.I decide if something works. My informed opinion based on my years of experience gives me confidence in what I personally hear. Your hearing may differ.
Is it hearing or brains that differ, I vote brains ?.
Dan.
'Off the wall' relative to what lol ?.You fellers are gonna have a field day with the next Hint Saga development.....
This one is so off the wall i’m Gonna wait till it rests over night to see how it fires up tomorrow....stay tuned!
Dan.
I suppose you confounded "educated guess" with "informed opinion". The first might work now and then.
That reminds me at a "Poesiewürdigungsstuhl". Sorry I did read the Hitchhikers Guide
To The Galaxy in German... A back translation will probably fail.
Why is visible part of spectrum the only frequency band of interest ?.......I will now feed the trolls by admitting that physical appearance and audio effect are both electromagnetic phenomena. The minor snag (for those of us from a science background) is the huge disparity in the relevant part of the frequency spectrum: audio roughly 20-20kHz, sight around 400-700THz, a ratio in the region of 10^10.
Dan.
Given the audiophile buttons pushed here, and the dismissing of proper engineering, I can only assume that you are commercially involved in audio or would like to be.
'Dismissing of proper engineering'. I think I am the engineer I think you have been with your bias for a very long time, no, I'm not commercially involved in audio. But yes, if i could protect IPs, may be i would like to be involved. But i'm also convinced that (product) 'quality' is not the main ingredient to be successful in business.
This was a helpful suggestion Dan, you could try it, prove DF96 wrong maybe?
Tournesol,
I have no idea. Perhaps Dan could put a set of black/grey/white wires through a MRI scanner and see what happens.......
All materials, whatever they, have properties of one sort or another, and as such will have an effect. It is not up to me to say what the effects will be, that is the domain of the electronic engineer.
But I will point out what is the bleeding obvious.
ToS
Is it your turn to "point out the bleeding obvious"?But i'm also convinced that (product) 'quality' is not the main ingredient to be successful in business.
What would one look for with an MRI scanner ?.This was a helpful suggestion Dan, you could try it, prove DF96 wrong maybe?
I have recordings that illustrate audio system effects, physics proof I do not have.
Dan.
And "open minded" individuals always behave?
Would not say so generally, but in this context and judging from several closed threads they did.....
There are some thoughts again about 35kHz, 100kHz, rise time, SR etc. in this thread again. For those with exceptional hearing abilities, like Dan, John and others I have created a new test
Can you hear sound above 21kHz? - listening test
There are 2 files, one of them has sound components up to 30 - 40 kHz and the other one is abruptly cut at 21 kHz. So feel please feel free to test your ears, and of course an ABX result will be more valued (by myself) than a mere statement "I can hear it".
Dan,
MRI stands for 'Magnetic Resonance Imaging' a process of using magnetism and radio waves to create pictures of features inside the human body. My prologue for an experiment would be to put wires, cables, and interconnections inside an MRI scanner, apply musical electric currents, and see what happens. I have no idea what would happen, or what would or could be seen to happen. Epilogue unknown.
But it is about time that somebody does it, or some such experimentation like it, as this fruitless circular conversation is going nowhere other than to damage the participants.
ToS
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
