I used to when I was fed endless marketing hypes based mainly on flawed research by Dr. Ancel Keys. Then I was fortunate enough to be directed by a friend to the info on the real story behind all that marketing hype. You should do some research on this too, for your own benefit.And don't you believe it's the same process in the opposit direction ? I'm sure you think of it too !
😱 Where have you been all these years when they debunked the audibility claims of expensive audio cables in double blind tests?What would be going on in one's psychology to need a double blind test? Some trust issues I think...
I've heard of transgender. Is this something similar?But is it not a transanimal?
I think we're talking species dysphoria.I've heard of transgender. Is this something similar?![]()
I think so.
Though not all people with species dysphoria have gender dysphoria, and vice versa, overlap exists.
This is interesting subject.
Pic of some text on link two pages back.
So it seems vegans may be high risk Guinea pigs for untested ( and unlabeled ) GMOs.
I was vegan for three years and had good results but that was many years ago.
I have no idea what we are eating now. Labeling is not required..
Long term side are effects obviously unknown.
T
This is not true. Labeling is required. If you want to take the stance of a conspiracy theorist then there is no point in having a discussion.
In the UK everything is pretty much labelled.
We have had a couple of people die who had allergies and the items they ate didn't have correct labelling.
Much of the food you eat is irradiated with cesium-i 37 , no conspiracy just true.
Try and find it on a label. The ignorant Margret Heckler allowed it in yes 1984 under Regan. She said consumers would be frightened by such labeling. Such thinking continues today with GMO.
Irradiated and BT products are coded at the wholesale level as is most GMO but not at the consumer level.
Do some digging on labeling policy.
Yes, that was quite shocking that there was no compulsion to label, still isn't under those circumstances, just a recommendation I think, if you are talking about the girl who bought a sandwich?In the UK everything is pretty much labelled.
Jfetter seems very sensitive to GM, irradiated food and who knows what else. We should watch him as a test case, maybe he'll turn into a Borg? Or a tribble....
He said he has a compact Geiger counter at the ready, maybe he could try to analyse the food first, and then some "end product", see if there's any radiation and where it "ends up".
As I said a conspiracy theory. It is easy to go to the FDA site and read the labeling requirements on many things, but it's easy to simply say everyone in business is a liar or a cheat. The long list of recent salmonella outbreaks is also evidence to the contrary.
The FDA requires that irradiated foods bear the international symbol for irradiation. Look for the Radura symbol along with the statement “Treated with radiation” or “Treated by irradiation” on the food label. Bulk foods, such as fruits and vegetables, are required to be individually labeled or to have a label next to the sale container.
- Member Areas
- The Lounge
- Veganism
