600W Class D amp
Hi dear manoj
I use T106-2 core with 60 turns of 0.75 wire and 3uf output cap and with these value the output signal is the cleanest and the sound is so clean
as I said before by increasing the 1K resistor I can increase the frequency, so I go higher than 1K and now I have 250kHz frequency
do you think that there might be some problem with my amp?
I ordered T157-2 and I will be using it for my 800W amps
I'll appreciate your help
* those are important components
MANOJ
