Ignorance as a resource
my personal experience tells me that the above mentioned 'tests' were not conducted correctly (not on large BQP), and as for 'analysed' that just tells me that the analyst does not fully understand such device.
Dan.
Dan, I guess you do understand that such a statement is completely irrelevant as to the question whether these devices do anything other than pay for a luxury car installment, and that you make it in jest ? 😎
Jan
And neither did SY or SW or Cal try large BQP.
Dan, with all due respect, are you aware of what they cost? I purchased a pair of the small ones, used them how I was instructed by the manufacturer, broke them in, in a manner suggested by JC and proceeded to implement them in my rather large array of high and mid frequency drivers.
As you know, I was unable to discern a difference. They simply didn't do what they advertised or at least didn't do in in a manner I could detect.
Please explain what motivating force there was for me to consider purchasing something more from the company when the product in hand was more than a little disappointing?
Snobs have the money so we need to sell them something to get their money and redistribute them in an ethical manner if we really are what we pretend to be 🙂
Lets be honest, most of the engineers are very poor at selling their tallents and then of course they become envious on the natural sellers ! Unfortunately engineers die engineers and usually poor compared to the poorest seller.It's just life!
I still remember a famous painter who once was asked to give a price for one of his painting and he said : i want 1 million dollar for this painting.The client asked...Why do you ask so much money?What makes it so valuable?Why don't you ask 100 000 dollars or 2 million instead?The painter said...I don't know...I put all my soul in it and besides, 1 million dollars sound awesome!
Hi Cal.
Yes, I am well enough aware of what they cost and it all depends on your gear and your disposable income as to whether they are worth while.
In the case where you had only one BQP I think it was a mistake to use on one driver only (mid or high) instead of at the input of full range loudspeaker box....you would have been better to compare boxes and not drivers.
The BQP sound is unlike anything you have heard before, and is reasonably subtle but once heard can't be unheard.
The effect is a 'reclocking' or 'dithering' of the current noise and all items connected will be changed.
The treated driver sound may be masked by the untreated driver sounds causing the false negative.
If you were to try them again as I suggest you will likely 'get it' and then be fascinated.
I have moved on to my ear more correct and musical solution, BQP works but does have signature.
Dan.
I had two. I tried them individually, in parallel and in series. Didn't turn a pig's ear into ham.
They do not recommend using the small ones in a full range circuit. Did I mention I used them as the manufacturer recommended?
If I get the chance to listen to the larger ones, I will do so with as open a mind as I had when I tried mine. Sadly, I won't be purchasing them myself as once bitten...
Anyway, I won't continue to pollute Jan's thread here, that's not fair.
The Bybee is said to be connected to the circuit, but to illustrate even closer from the first post, one could talk of the "famous" resonator of Mister Chang or Tchang (doesn't remember exactly) :
change the sound, is made from mix of wood and a metal bowl above it : different models : copper-plated; gold-plated, silver plated, etc... two or thre different size, very expensive. Reviewed in all the world in many paper and electronic magazines...
Sort of illustration of the placebo effect in relation to the monney. It is not from big data, but purchasers saw ads in hifis paper mag. so sort of cunsumers pre selection. Certainly was already talked in the Snake oil thread, dunno !
