100W Ultimate Fidelity Amplifier
Hi
Does anyone have PCB(toner transfer) for this protection?
Joined 2013
I have a few questions on the FH11/12 deisgn posted in the thread. Plan to use @eaglemaster v1.07 gerber files from post #8557.
1 - Is MJE340/350 interchangeable with KSC3503/KSA1381? I see both on different versions of the board throughout this thread. Datasheet leads me to think they are, because they have similar parameters with the MJE's have higher current and disapation capabilities? Can someone confirm?
2 - Can I also substitute BD139 for a MJE340 - or is that overkill or not suggested?
3 - What are R40 & R41 (22r 1/4w 1%) but not showing on the PCB silkscreen?
Hello...
I have read the pages of the forum to start the assembly of the AX11, I had some doubts, but I found several circuits, I had some doubts:
Can I power AX11, AX14, AX17, and SD200 with PSP100, speaker protection involves delay speaker, short circuit and DC?
Which amps are PSU 05 and 07 for?
Thanks for the force !!
(using Google translator)
Joined 2013
Anyone able to answer these questions?
Founder of XSA-Labs
Joined 2012
Yes - it can work welll. KSA1381/KAC3503 are probably even better.
The Vbe multiplier just needs to be a NPN silicon transistor.
I am not sure I see R40 or R41? There aren’t that many resistors.
Joined 2013
They only show on the schematic (R1 on v1.0 and R40 on v1.07(snip below)), on the Power inputs (+ & -). It appears they are safety resistors for initial startup - Maybe???
Any thoughts on the MJE340/350 vs KSA1831/C3503 substitution question?
