MOS 200
Is this pcb available in black&white for home etching?
Is it tested?
Any black&white for home etching?
sir still4given very good drawing please share in sprint layout .
Here you go.
MOS200 with the 1k trimmer per schematic.
50x45mm
Hi
very good and small size
this need short and DC protection
do you have any sugestion?
Hi
How about the F100 power supply and protection.
Thanks Mile, is it safe without source or drain resistors?
Please can you answer my question?
Thanks.
Thanks.
Yes it is safe if you use it with PSU100 (F100 PSU and Protect)
Thanks!
I ask because i had read that Mondarbo have issues with sutch a circuit without resistors and there is a modification using resistors to solve the problem.
Thanks!
Set bias to 20mA and there is no problem.
Thank you very much!Set bias to 20mA and there is no problem.
You do not need resistors with single output pairs just BC546 must be on main heatsink with outputs.
- MOSFET Amplifier IRFP240/IRFP9240
