500W PA amplifier with Limiter
I can't see any 0R47 Ohm. resistor.
Resistors that i see IN YOUR PICTURE are 4K7, 4700 Ohm!
ty for helping thimios,
i make pictures
Measure voltage at 15v zeners.
Measure voltage across 0.47 Ohm.
Use a bulb in series with the transformer primary to save your amplifier .
ATTENTION when working with the main!
DANGER!
Use a combination of a cheap speaker in series with a 1000uf electrolytic capacitor as a load on the amplifier speaker output.
Play some music.
DANGER!
Play some music.
on zeners 15.4v
on 0,47ohm 0v
which kind a bulb do i need to use on it i have 10a fuse on board its not saving the amp?
not: when i give ac power, audio output have 0V. when i cut ac voltage then on audio out getting dc voltage and raise slowly to -9V i just see that luckly
Play some music.
hi timos i did play music 🙂) 3 channel b500 burned. r21 (100R).
any one please help if you have time i need finish this amplifier killing me.
my 2 channels not work good but 1st one was working good but now 3 channel burn R21 100R same resistor.
and they burn 5200 transistors too 🙁((((((
