LM4562 for $1.60
Don't panic - test it!
Here a test procedure from TI: https://e2e.ti.com/cfs-file/__key/t...nts/00-14-01-00-00-80-75-78/Popcorn-Noise.pdf
I don't believe they sell out of spec opamps after this well known article.
If you use low input impedance circuits as D.self recommends in his books you will have less problems using opamps based on the described production process.
BTW: The NE5534/NE5532 was an expensive opamp in the first years!
BR, Toni
Have a look into the datasheet - there is information about noise density in datasheet. And popcorn noise can affect ALL opamps which are made with the same process - not only TI ones. The described ultra top performance of measured LM4562 opamps which was the need of one customer is only achieveable if he selects the best out of a big batch. IMHO the so called bad ones are mostly or all still in spec. Every transistor has a hFe min/max and noise min/max and you always need to select your pairs yourself. If this panic leads to the low price - no problem - I buy more and pre-select it for the application I want to build.
BTW: the above link to the so called bad opamps hasn't described the test method? Or I'm unable to see it...
BR, Toni
BR, Toni
It seemed to me that the noise measurements weren't very far from the datasheet which is a big vague under 100hz, plus nobody knows
WHAT WAS THE SIGNAL SOURCE IMPEDANCE !!!
There's one more thing...his graphs are too linear in the 0-300hz region measured, even more linear than the datasheet graph which is a bit weird...
The guy is very picky...anyway, as i consider them perfect for unity gain line level.Now it became a true bargain and TI behave as professionals selling them right away but it might lead to a very different outcome, one that nobody really wants.They might cease 4562 production and launch a new model with odentical but verified specs at 3x the original price...
I was interested in LM4562 2.7nV/rt Hz until I got aware, many are out of specs, unusable for low noise applications.
May be a good bargain for other applications.
Do not think, noise measurements at these low level is easy.
No doubt a guaranteed 2.7nV/rt Hz op-amp is worth 3 times their dumping price.
You can use your opamp to run high gain of >=100 to increase the noise output. Use an output filter to measure only the low frequency range e.g. < 1kHz or < 100Hz. Use battery powered little metallic case, put your opamp test circuit in there and use your scope to measure.
For DIY an absolute value is not needed as long as you have some sample opamp to compare. Buy some different "ultra low noise" opamps to compare ...
The above link from post #11 - popcorn noise measurement pdf will help you.
BR, Toni
