New Celestion "AxiPeriodic Driver"
@ speedy6963
Not jealous 😀
One of the reasons they are more expensive than we first thought, must be due to them being made in the UK ! I wonder why, & how long that will last ?
Thanks Rob. I wonder what happens past 12 kHz?
That is pretty much beyond 'the vocal range' for which the Axi2050 was intended, so maybe Celestion didn't consider it relevant 😀
While I was searching for the origin of some good ol' fiberglass diffraction horns that I've bought, I stumbled upon some Outline horns that look quite similar to the Celestion LH9045R.
The Outline horns are a bit smaller though and 60x40.
Another interesting large format driver that was recently anounced:
QUICK ACOUSTIC SPECS
Nominal Impedance: 8 Ohm
Minimum Impedance: 8.3 Ohm
AES Power above 0.9 kHz: 120 W
Maximum Power above 0.9 kHz: 240 W
Minimum Crossover Frequency: 0.7 kHz
Sensitivity (1W/1m): 109 dB
Frequency Range: 0.5÷20 kHz
Voice Coil Diameter: 86 mm (3.4 in)
Diaphragm Material: Ketone Polymer
Diaphragm Shape: Annular
Flux Density: 2.2 T
Re: 6.8 Ohm
Phase Plug Design: Radial
The measurements where done with the LTH142, which is way too small too unleash the full potential of this driver.
The breakup looks modest and Faital's plots are usually not far from reality and the Ketone Polymer diaphragm provides a smooth sound.
People have used the smaller HF144 from 600-700 Hz without issues. This one should take 500Hz.
It remains to be seen whether the radial plug does well with a high flare rate at the throat.
