Defo
If the amp goes into protection mode just after connecting the crossover, there must be a major (short) problem. What I meant … did You try the same speaker with the same crossover or did You swap them ? Do you get sound at low volume for seconds or does it trigger protection right away ? It shouldn't trigger protection at low volume. Perhaps the amp is faulty and not the crossover.
Defo
I get sound before it goes into protection for about 6 seconds. Then normal operation with sound for a second or so before it goes into protection again. Pretty weird... Amp works perfectly fine with all other speakers I've tried previously.
That will depend on what fault the protection system is tripping on.
Voltage, current, temperature.
And each one could be cause by different, or multiple issues.
A 10 litre bucket will hold 9.9 litres all night and day.
Pour another litre in and it will fail and over flow the extra 0.9 litres.
Since one crossover works, I would suggest swapping one part at a time between good and bad boards.
Use a bit of tape to mark the parts on the failing unit to help you keep track of what you have and haven't changed.
I'd also write a list of all the parts, then put a line next to it when you change that part.
Once a single part is swapped, retest both crossovers.
That will help eliminate any issues with assembly.
But the photos you've shown look really neat.
Time consuming and a pain in the ..... but it means you don't need test gear or a bunch of new parts.
Could you post a photo of the top and bottom sides with both units next to each other ?
I wonder if one part is not in the right spot.
Perhaps the short is elsewhere. The crossover functions because
there is nothing wrong with it.....but you may have a parallel short
Have the crossovers been swapped between channels, with all else remaining exactly the same?
If so, did the problem change channels, along with the (supposedly bad) crossover?
There was a time when I had zip-tied down a coil, and the ratcheting of the part to the board allowed the urethane on 2 places of the coil to rub and short out. It is possible that the coil in the tweeter spot might be doing this. This could look like a short to the amp.
Later,
Wolf
This might be a point. In this case, each coil on itself would still measure 0.8 ohms and seem OK, but the short wrecks the operation. The test for this could be a resistance measurement between the end of one coild and the end of another coil.
Jan
The components are hot glued to the board It's probably doable cutting the glue, but it will be quite an undertaking. I guess this might be the last resort.
Swapping just the crossovers while having everything else exactly the same - the problem does indeed change channels along with the bad crossover.
Jan
Tried measuring now. Still get 0.8 ohms for both boards.
Just to make sure, I've attached pics of where I measured:
An internal short in a coil will be hard/impossible to see normally - trying to run it at high power may provoke visible arcing, but may also damage the amp and speakers.
Close visual inspection (ie with a magnifier) might throw something up (perhaps one coil
got scrapped by a sharp metal object?).
There might be an intermittent capacitor or solder joint that only shows up with higher voltages/currents than a multimeter will provide.
[ postings overlapped! Good to hear its figured out now - the cap is either shorted, open or intermittent, whatever it just needs replacing with a non-polar equivalent ]
Eureka! Disconnected the big cap for the woofer and now all is good! This begs the question tho, what is wrong with the cap?
My guess is an intermittent short in the cap, sensitive to either vibration or temperature. Electrically, there are two conductive "plates", separated by a dielectric material. Sometimes a metal film is deposited directly to the dielectric, or a layer of metal foil alternates with the dielectric film. To save space this is wound in a tight little bundle. One plate could short against the other if there is physical damage or a defect.
Once the short circuit begins there will be a sudden spike in current through the cap, which would generate heat. This might be enough to maintain the short circuit until it cools down, or the short occurs frequently enough that the protection circuit is retriggered.
We don't know yet something is wrong with the cap.
A quick test would be to temporarily fix the 'good' cap to the 'bad' board, to get confirmation it is the cap and not the associated wiring.
Jan
Just did this, and it's not the cap Now I really have no clue...
Well you've swapped one cap.
Now keep going with the other parts.
One at a time, then test both crossovers.
Isn't it possible to deduce something from the fact that removing the big woofer cap fixes the issue?
If we knew what the circuit was, then yes. Since it's of proprietary nature, we don't know this information.
Later,
Wolf
See attached pics. Pretty sure its correct.
First is board layout.
Second is schematic based on board layout.
Third is re-arranged to make it easier to read.
Hope that brings some value!
- Crossover makes amp go into protection mode
