Nothing wrong with a 10-12" doing 150-1100Hz.
In fact mated to a good waveguide 1100Hz is a decent frequency to get a directivity match.
Interested in better understanding this notion. What kind of waveguide and what would the waveguide do for this? Have an effect on the higher part of the range or the lower end of this range (my understanding is a horn would be needed for this).
Following this approach, I wonder how high an 8" mid woofer could be good at.
There's nothing really much to it, Geddes speakers all follow the same basic principle.
A 6" woofer with a 6" waveguide have pretty much the same directivity profile. That is the woofer starts to beam as the waveguide starts to control the tweeters directivity. These two overlap/match in frequency. The ideal is to pick a woofer that can cross over during this narrowing of directivity and crossover to the tweeter around this point. So for a 6" driver you would want to cross over around 2200-2500Hz.
An 12" would better suit 1100Hz cover as mentioned above, but it'd be done with a 10" too provided the tweeter on waveguide could handle it.
An 8" would do well crossed around 1700Hz.
Most metal cone drivers do not suit this approach because they need lower xovers to mitigate their harmonic distortion peaks. You can get around this by crossing over before the woofer starts to beam but it places additional demand on the tweeter so you need something that can cope.
A driver that bucks this trend is the SB17NAC with it's ribbed metal cone and lack of harmonic distortion peaks.
This is probably getting off topic although I suppose it is relevant to the use of large PA mids and mid bass drivers.
The famous JBL engineer Drew Daniels offered up an all-out system design with the JBL high eff midrange 2123H at its core:
Untitled
This is well worth reading! Note his comments about using a cylinder enclosure 1 foot deep and filled with fiberglass (and ONLY fiberglass!!!) as being crucial to extracting the best from the 2123H or the subsequent, still higher quality JBL 2012H.
Fwiw.
I cannot attest to this personally, but I plan to try a short transmission loading with a ready-made 4 foot folded t-line by Obcon Single 10" Labyrinth from eBay. I'll be using the 18SOUND 10NDA520 with some UltraTouch recycled cotton insulation.
Alex
Untitled
Fwiw.
Alex
Oscar, just curios why you rejected the Faital drivers? I’ve got the 12HP1030 and think they are pretty good....
I agree they are pretty good. The 10FH530 had the least variance in it's frequency response compared to the rest! I just like the other ones better from a harmonic distortion standpoint.
Thank you 5th elemen.
I got two RCF 10L-750YK and they are excellent in the range 175-1100hz.
Very open and clear sound.
Greetings to all !!!
@ OscarS
I beg your pardon Sir, the Beyma 10mc700ND tests will follow or there are new programs in this regard.
Thank you and greetings.
Mleod
@ OscarS
Mleod
@ OscarS
Mleod
yes the Beyma 10MC700ND tests will be done, results probably in mid-late June.
I had thought about acquiring a pair of those, but the limited Xmax kept me away from them, as well as a limited F(-3) point. Have you tested the harmonic distortion of those?
I have not.
A pair of Beyma 10MC700Nd's are on their way to me. Even though I already have the HD data from the manufacturer, I'm going to test them so they are on the same level playing field as all the other 10's I tested. Also, I like to convert the raw dB values to percentages to aid in analysis.
Looking forward to it, have my eyes on this for quite some time, plan to mate it with the TPL150H in a stand mount I have in mind.
Let's see how these do. Gonna break them in.
Big thanks to Jay @ Loudspeakers Plus for the great deal!
T/S Parameters for the Beyma 10MC700Nd. Unit was cold, but it was already broken in at full-Xmax with a 20Hz sine wave for 1 hour. T/S parameters did not shift much after break-in, which to me is good because it says the sound character should be consistent either way. For all practical purposes, they are reasonably identical.
Would be very curious to see how the Eminence Kappa Pro-10LF would test. I am considering an application using them from about 80Hz to 300 Hz.
Send it to me and I'll test it. 🙂
- War of the 10" monster midbasses
