Salas SSLV1.3 UltraBiB shunt regulator
Hello Salas,
Is possible to measure the rpi3 headless with hdmi disable, no screen, mouse , keyboard, and wifi?
Only ethernet...
I use it as a music player like that with volumio, or picoreplayer or max2play . I use a nas or pc to store music files.
Tks.
I downloaded and burned on mini SD card this image from your list of players to test. I use Foobar on W10 mini PC myself. I don't know how to go about this cruel RPI decapitation stuff 😀
That's the way Archphile, my distro of choice, is set up to run by default.
Such a configuration has very low power consumption, definitely less than 500mA.
OK I also burned that one's image and run it. 522mA max (moments) and 212mA average during boot. Then it turns the HDMI off, the green lights don't blink anymore, and it pulls 217mA steadily.
I've built the +- ultraregs for 15V and they are running fine.
Built up a +V ultrareg for 5V.
These are tea-bags pcbs & kits. The +5V kit came with PF5102
jfets marked as 8.9 4.4 9.0 .
For the J3 position I used the 4.4 jfet.
Powered up the pcb with a 9volt xfmr and no load on the output
and the output voltage is 12+ volts and cannot be adjusted with
the pot.
Any suggestions as to what I can check for, all solder joints look
good and none bridged. I need to verify resistor positions and
values, all resistors were metered before installing.
Thanks Ichi-
Then Q2 & Q3's Vbe. Circa 0.61V each would be healthy. By the way when having a 20k voltage trimmer (VR1) it may take quite many turns before it will respond for lowish settings. Since that value is to cover a large 5V-40V output range, and as it comes midway set from the factory, it should be trying for about 25V in this circuit.
No shorts of tabs to HS.
Will check Vbe s .
On the pot I ran it all the way up & back, with no voltage variation.
