ICEPower 50asx2 kit
I bought 2 125asx2 modules from the first ebay link. They are the real deal. Installed in Ghentaudio cases with rtx modules, probably a bit overkill for a desk top system. In my opinion 125asx2 is a much better value than the 50asx2 at the moment. I tried a topping d50 and a Sabaj Da3 dac which worked fine without balanced inputs straight into the ice module.
The Emotiva PA-1 uses ICEpower 300ASC, pair would cost US$600 and free shipping to Canada.
140 watts RMS into 8 Ohms at 1 kHz at 1% THD;
135 watts RMS into 8 Ohms at 0.1% THD.
300 watts RMS into 4 Ohms at 1 kHz at 1% THD;
270 watts RMS into 4 Ohms at 0.1% THD.
450 watts RMS into 2.7 Ohms at 1 kHz at 1% THD
How much total cost was it for 2 125asx2, Ghent case, and parts? Is the watts output comparable?
That Emotiva PA-1 is a great option. So far the Ghentaudio option has probably cost me close to 400(taxes in) per mono block. So 800cdn plus tax for a ready made solution from Emotiva def sounds like a better option to go.
What is your plan for dealing with the balanced input only option of the Emotiva?
From the PA-1 Manual, it does allow for unbalanced input, just need an RCA to XLR connector.
---Manual Page 11 ---
If your source device only offers an RCA unbalanced output, you can easily find low cost
adapters and adapter cables that go from an RCA connector to an XLR connector or a 1/4” phone
connector.
My mistake, shipping is $20 DHL, comes with 5 year warranty.
I was curious about the Ghent GA-M500P, from Ghents reply it has one 125ASX2(BTL) inside with a Mono input buffer. Costs US$675, compare that to your DIY $400.
Maybe one way to get the cost down (US$477) is to use one case for dual mono. I asked Ghent if I can get a DIY case similar to "GA-S500P Stereo Power Amplifier (Dual Mono)" amplifier.
1. Two 125ASX2(BTL) - US$277
2. Dual mono Case - US$120
3. RTX Module (pair) - US$80
Good to know about Emotiva-1. For the input just use an adapter like shown below, they work great.
BR
Eric
The RTX is needed because it act as a buffer or a preamp since the input of these IcePower have a low input impedance and do need a buffer to sound their best.
The IcePower 300 series don’t need a buffer since their input impedance is the regular 47kohm.
BR
Eric
I loved my 125asx, until I dropped and broke it. 😡 Very clean, great bass control, easy to use. One friend criticized it as being "soft on top" - but I just found it to be clean and natural on top.
Got an updated quote from Ghent. Total cost will be $587 to build the exact GA-S500P, vs buying a fully built one for $1350.
Will cost the same as an Emotiva PA-1, advantage is more output power.
500w x 2(4Ω), or 250w x 2(8Ω) - Two 125ASX2(BTL)
300w x 2(4Ω), or 140w x 2(8Ω) - Emotiva PA-1
Cost breakdown
1. GA-S500P Stereo Power Amplifier (Dual Mono) DIT kit US$310
-200mm x 315mm amp case with dual-mono rear-plate
-all needed audio connectors
-RTX-B(0db, 100K) module
-Custom Power supply/signal Harness for two 125ASX2
2. Two 125ASX2(BTL) - US$277
If only the 300ASC board was available for purchase. What do you guys think?
Another way
Cost breakdown
The theoretical and preparation phase is gratifying. I try to prolong it, by collecting discarded electronic stuff for a couple of months.
Old cases have thick and non-optimized sheets.
If I buy cheap accessories, they simply don't work. If I buy quality parts, I spend on them as much as an industrial device. Instead, I can get functional parts from garbage.
Wrong purchases of the past can be rethought.
Sustainable.
If you are looking for ICEpower amps how about this XTZ:
XTZ EDGE A2-300 power amp - XTZ Sound in Balance
I'm not an expert but it looks well built, I think there is also some sort of buffer on the RCA inputs. Has good reviews and fair price.
On the other hand, Allo Audio is working on a TPA3255 AMP.
I for instance am waiting to see what they can get from that chip 🙂
Comparing the pictures, Emotiva PA-1 and XTZ use the exact same 300ASC icepower board. Only difference is Emotiva is mono and XTZ stereo/mono selectable. Price wise, the Emotiva is cheaper, 495 € = US$553.
Actually these models are not using the same components:
Emotiva PA-1 is monobloc using 1 x 300ASC / ch.
XTZ is stereo using 1 x 300ASC and 1 x 300AC (amp only powered by 300ASC)
The Emotiva should theoretically cost more.
BR
Eric
I think* 500E includes local VAT (~20%) that is not paid whne exporting outside EU. However the prices are comparable and probably both amps are good.
