There is room for changes in our design, but our current intention is that it would be connected to the DAC only. Do you consider it important for a lot of users to be able to use the unit as an AES/EBU>USB interface too? I remember you mentioned using the computer for some DSP stuff earlier... however, we have a dedicated product containing a DSP (DAC8 DSP)... also that DSP computer could serve as a playback source too, avoinding the AES/EBU alltogether.That is great news!!
Are these inputs directed directly to the DAC, or to the USB soundcard?
Up to 15.8Vrms theoretically, 15V rms with some safe margin. I've added that to the website too.Another question.
The specificartion states "8x XLR balanced, 3.4V RMS differential (or per request)"
What are the available output voltages?
Okto Research converters does not suffer from that. The THD+N or IMD vs. output voltage measurement yelds almost a straight line with a very slight bend towards full-scale (due to the THD component).Okto research, are you aware of the ”ESS hump” mid-level IMD that seems to plauge a lot of ESS implementations, and did you adress it in some way in this design?
Pavel
Thumbs up!
This requestable output voltage is very nice 🙂 Could it even be different output voltage per channel? For example if I would want 2V on 4 channels and 9V on 4 channels? (I am using different kinds of amps for the woofers and the horns in my active 4-way speakers)
I would love to have the option to route the AES intput to the USB soundcad indeed!There is room for changes in our design, but our current intention is that it would be connected to the DAC only. Do you consider it important for a lot of users to be able to use the unit as an AES/EBU>USB interface too? I remember you mentioned using the computer for some DSP stuff earlier... however, we have a dedicated product containing a DSP (DAC8 DSP)... also that DSP computer could serve as a playback source too, avoinding the AES/EBU alltogether.
I am currently working on a correction+streaming solution (rePhaseR) that requires some power and a x86 architecture...
Regarding these AES inputs, I suppose they all need to share the same clock? Or is there some sort of ASRC like in the UDIO8?
Lucid did something clever in the 88192, where you could choose to either sync to the first AES input (all inputs needed to be on the same clock), or to set an ASRC on each input individually.
http://www.symetrix.co/repository/88192_ug.pdf
25.7dBu!! That is some crazy level 😀Up to 15.8Vrms theoretically, 15V rms with some safe margin. I've added that to the website too.
Is there any drawback regarding THD, etc?
How do you set this level? Do you need to change SMD resistors, or would there be a way to calibrate it using a screwdriver or something?...
Out of curiosity, why did you settle on 3.4Vrms as a default instead of the more common 4Vrms for domestic devices?
Thumbs up!
It could be done, it may however, become inconvenient if you decided to change your amps in the future.
There are menu settings for individual attenuation of each channel (relative to the master volume). It is of course at the expense of dynamic range (which is 125dBA full-scale), but it is much more convenient.
Still, you could use the DSP computer as a playback source too (or a DLNA endpoint, Roon endpoint, whatever).
We decided to make the inputs run on the same clock, synced to the first one. It seems as a cleanest, simplest solution to us.
There will definitely some THD penalty at the top end. I believe the sweet spot is between 3 and 8Vrms.
The analog gain of each channel is set with a pair of a very precise, thin-film resistors. It is thus not possible to adjust it in a simple way.
No particular reason. Over time, we may settle on 4Vrms or other value that customers will be most interested in as a default.
Thanks 🙂
Can't wait to read Amir's review: Reasonably priced good quality 6 or 8 channel USB DAC? | Page 11 | Audio Science Review (ASR) Forum
Unfortunately I need more power than what a Rpi can offer.Still, you could use the DSP computer as a playback source too (or a DLNA endpoint, Roon endpoint, whatever).
Review and Measurements of Okto DAC8 8Ch DAC & Amp | Audio Science Review (ASR) Forum
Nice results for sure!
Two feature requests (as I plan on being a customer soon 😀) :
- could it be possible to route any of the 4 stereo pairs to the headphone output via the menu? That would be very useful for checking outputs in an active crossover scenario (or even a 7.1 one for that matter).
- Making 4Vrms the default output would probably be a good choice, to match existing DACs. This can also be an important point for subjective reviewers, as a higher level usually translate into a "better" subjective feeling...
I would love to have the option to route the AES input to the USB soundcad indeed!
I would love that option as well (and I am going to buy this product).
+1Option of rack-mountable front plate would be nice.
There could be a pair of removable rack ears that the end user could choose to install.
What a pleasure read ASR review that pushes to limits of analyzer, first class work there : )
Myself is in same boat as pos and Rajapuk and would love one input to USB sound card so that OS will se 1 stereo input and 8 channels of output, pos request AES input but will also be nice one could optional order ADC in front there. To explain usecase here or lets say dream usecase in this objective DAC8 wonder is have JRiver as multiway speaker DSP locked at 192kHz, JRiver engine is running 64bit deep and it looks into a 32bit deep ASIO USB interface, then one can massage a high performance accoustic passband way up above 20kHz because DSP is at locked relative high rate and if input is ADC then its up to DAC that feed system to be true to native track material rates and filters. Know there is some pro interfaces out there but they lack consumer or configurable voltage levels and also who has seen a independant review reveal objective graphs.
Best thing would be to have the option to route the 8 inputs together either to the USB soundcard or directly to the DAC.
That way you could even have a software source selector by selecting a given AES3 stereo input in your crossover software (that is something I am currently using a lot in my rePhaseR crossover implementation with the UDIO8).
Okto Research, I wish you well, guys! Congratulations on creating a reference quality product. I definitely need one too.
My requests: 4Vrms output, black faceplate and model name on the face would be nice too.
Very interesting products, congrats!
Any chance of SE as well as XLR outputs for stereo version?
Is the IR input speaking with the Raspberry pi inside, or is it for the DAC board only?
Im thinking like play/pause and skip commands 🙂
I guess they are super busy right now, but I'd love to hear back from Okto on the different questions/requests here before ordering.
I would love to see 1kHz THD measurements for the different output level options (3.4V to 15V, lets say 3.4V, 4V, 7V, 10V, 12V, 15V).
#metoo
Hello everyone!
Kindest regards,
Pavel
Unfortunately, no. The headphone amplifier is hardwired to CH1&2.- could it be possible to route any of the 4 stereo pairs to the headphone output via the menu? That would be very useful for checking outputs in an active crossover scenario (or even a 7.1 one for that matter).
We decided to make 4Vrms the default value.- Making 4Vrms the default output would probably be a good choice, to match existing DACs. This can also be an important point for subjective reviewers, as a higher level usually translate into a "better" subjective feeling...
And there will! Just need to update the website.There could be a pair of removable rack ears that the end user could choose to install.
I actually had a few sleepless nights. But thanks 🙂.By the way sleep well in Prague tonigh : )
We decided to make an option for black faceplate! Please specify that (and the voltage) in the order note. No model name on face panel, though. Making them identical for all models is helping us to keep the cost down.My requests: 4Vrms output, black faceplate and model name on the face would be nice too.
No, sorry. Using SE signal paths between multiple devices does inevitably degrade the real-word performance since any electromagnetic interference will cause a current to flow through the shield conductor (creating a voltage drop), which in case of SE also happens to be one signal lead.Very interesting products, congrats!
The IR is for DAC only. You still have to use a smartphone/tablet to choose songs etc.Is the IR input speaking with the Raspberry pi inside, or is it for the DAC board only? Im thinking like play/pause and skip commands 🙂
How about Intel NUC or other x86 options?Unfortunately I need more power than what a Rpi can offer.
Thanks!Spoiler alert.... . Stellar review @audioscience review. Congratulations!
The timeline to finalize the design is quickly approaching. I cannot promise on that. The intention with DAC8 is to make a very good D/A converter, not a universal interface.Best thing would be to have the option to route the 8 inputs together either to the USB soundcard or directly to the DAC.
We will try to obtain them when there is some spare time. As I mentioned, not much difference expected until the top end.I would love to see 1kHz THD measurements for the different output level options (3.4V to 15V, lets say 3.4V, 4V, 7V, 10V, 12V, 15V).
Kindest regards,
Pavel
That is quite understandable.Unfortunately, no. The headphone amplifier is hardwired to CH1&2.
Yes, that is the kind of platform I am using (Intel J4205). Are you planning on integrating something like that in a DAC8? Not sure that would be a god idea as these platforms are evolving/obsolescing much faster than DAC technologies.How about Intel NUC or other x86 options?
(about an AES in to USB path)The timeline to finalize the design is quickly approaching. I cannot promise on that. The intention with DAC8 is to make a very good D/A converter, not a universal interface.
I understand, but that mean I will have to use a second USB soudcard to handle inputs... Any hope of seeing a firmware update addressing this in the future?
Nice, thank you.We will try to obtain them when there is some spare time. As I mentioned, not much difference expected until the top end.
I think 7Vrms/19.1dBu would be a good option, and help preserve a bit more of that tremendous dynamic range downstream.
When you say "top end" I suppose you mean V, not Hz?
- Vendor's Bazaar
- Okto Research DAC8 PRO and DAC8 Stereo
