Simplistic NJFET RIAA
Salas: for the MC step up in the original Nfet phono do I need to change any resistor values (R1?) when using 8.2mA jfets?
I just finished my build and switched it on. One channel I get all the LED's and the other channel the 4 on the side never come on. I am overwhelmed where to start, are there common issues that would cause this?
Also, my Raw PSU is putting out about 27V DC. Is that enough? I saw in the biasing that it is looking for 35V
I built the MC step up. Sounds very, very good. But it's very sensitive to placement. It must be a meter away from my big class A amp for best results. But it is not in a metal box yet.
Running off batteries for now. Works as advertised.
Anybody compared this against a transformer SUT?
Good screening for sensitive circuits in traditional diy fashion comes with dead bug style construction on a raw board's copper back housed in a tin can. 😉
I prefer direct high gain input where hum and buzz problems can be solved without a step up transformer.
I think some of the problem with this is my turntable, a Rega. It has no separate ground wire and I was using the step up as dual mono (2 battery packs). The only way it was quiet was if I tied the Left and Right RCA grounds together.
Also, I experienced a strange loud BUZZ when I my hand was about one inch away from the record on the platter...Not touching, just hand above platter.
Hello Salas,
I was contemplating the same these days ; and started by acquiring tined steel boxes(1/chanel) composed by top and bottom plate and moving both gain stages in there. The main drawback is the ridiculously large inter-stage 100n russian mica capacitor that is at this point an antenna for 50Hz hum.
How one solves that ? a Polypropylene capacitor is linear enough at that point (anyone compared different builds with different interstages? R-Cruz maybe ?)
My status: In process of finding 100n mica's that are comparable in size to a jfet so all the stages except buffer to fit in a 3cm/5cm shielded enclosure(but it seems impossible).
If the big Soviet era cap has a metal shell see if you can scratch it somewhere and put solder on to run a wire from it to a ground point.
is aluminium
and funny you mentioned it; i managed to create a soldering point using a 22000uF @35V and some thin copper wire discharging it repeatedly in a pad like area 🙂
It seemed too much of a improvisation to mention or use it.
But after a couple of hour seeking an alternative; incorporating it seems a better option. But i will build a steel enclosure for it ; aluminium is worth nothing when it comes to shielding.
Cheers.
P.S So no comparison to just use a different capacitor or none ?
Aluminium is difficult to solder on but maybe you can devise a wire retaining band.
There are many good alternative modern capacitors. None is not an option, it's a coupling position and it's necessary.
About soldering on aluminium; thats the trick; just discharge a fairly large capacitor using a thin copper wire on its surface ; and after a dozen discharges ; a copper pad will be strong enough to magically solder where none has soldered before🙂
Ok ; i will just try some pp capacitors then.
When i said none i was thinking to simply a strap but i have little knowledge in the stability implications.
We see about that next. Maybe one LED is in reverse, or somewhere around them a voltage isn't right, something. If one channel is alright you can compare the bad one's voltages at points.
ok! so I have a new transformer in there and a 20R 5W in RD Link and I am now getting 51V DC out from the Raw PSU. At DC IN on the board, it is 44.8V. I was able to get the voltage to 35V between GND and RAIL+ for both channels.
The channel with the working LED's I was able to bias TP1-TP2 correctly to read 3V. The channel with the non-working LED's reads TP1-TP2 of 35.06V same as GND to RAIL+ of 35.06V.
I found that one of the LED's in the set of dark four was installed backwards. I flipped it around but they still didn't work. I am concerned i may have damaged the one LED when I was taking it out. It is one of the flat types from Teabag's GB and it now has a small crack on one side that half way across. I am concerned that if I need to replace it, that it won't match the other 3 in the set. What would you recommend?
Is there anything else I should be checking? Thanks so much for the help!
