insulated speaker cables
Well, I found a big part of it I think. I noticed that one of the RCA input connections was kinda loose so I started to tighten it when I also saw that the ground side of it was not making contact with the chassis.
After I fixed that it improved the 60Hz hum considerably.
I am so thankful to this site that I am going to give a donation in recognition of all the help that I got here.
Thanks again.
I got it fixed
And as you all suggested it had nothing to do with the cables. I had done a poor job of routing the cables within the chassis. After I got that sorted out, the hum as well as other extraneous noises have disappeared.
