Yes, use 22k for R10 and 10k for R6. No need to use cap accross R10. I prefer to use higher value of C7 and C8 to solve the problem of instability. In my AX11 builds I used 100pF for these two caps and have only very small overshoot on square waves. This circuit is AX11 without output transistors so I expect it to work even with 100pF. If you want to play safe use 220pF.
Should i change R10 from 10K to 22K as R2 for minimum output offset?Also could i use a 10p cap across R10 or from T6 collector to base of T3 to improve stability?
This is my simulation with slightly modification.
It can be even better to use another output devices, such as KSC3503/KSA1381...
Sajti
Agree.
Your google translate question made no sense.
the Apex amplifier 33 ... I put together a second channel . Output voltage rise to 4.7 Volt. It doesn't heated. looks like an amplifier excitation.
In this 2pic.what is correct about the direction of zeners
Second picture is correct direction of zeners.
Hi Mr. Mile,
Thank you for correcting me. My impression was like P30ZF is the right choice for A40. Now I understand that I was wrong 🙂
Thank you
Sha
Thank you
Sha
Dear kunal in fh9 how maximum dc voltage.i have 35..0..35 vac trafo .can i use it in fh9 ampl.thanksSonal Kunal - thanks! Looks fantastic. 😀
https://www.diyaudio.com/forums/attachments/solid-state/560703d1468819884-100w-ultimate-fidelity-amplifier-fh11-
It's very convenient that pin outs for BD139/140, KSC3503/KSA1831, MJE340/350 are the same. Note that on VHEX+ amp, vzaichenko drives a pair of IRFP's with a single KSC/KSA just fine so it may still be suitable to use those drivers. I believe they may have slightly better noise/performance figures over the MJE's.
I have both so it's not an issue - just wondering which will give best performance.
Hi, yes you can, 35-0-35 VAC it means 48-0-48 VDC
Sir i want to speaker connection in above said ampl.i connect spek.out and ground but not sound.plz help me thanks
You should chek the electronic components. Can you post fotos.
hellow everyone. i need a digital source selector for amplifier with default output or previous source output the amplifier was turned off but i dont find the suitable schematic 🙁 . i need help.
It is a scheme well known from Apex.. but I see Vbe multiplier transistor was replaced by a pair of diodes. I don't like that idea but it can work.
Want to build a Stereo Amplifier with Apex AX-14P + TB1 + TB3 + Apex 2x24V PSU.
Can someone help me with TB1 & TB3 toner transfer pdf.
Do I need PSU 5 for for AX-14?
Is this transformer (40Vac-0-40Vac @6 Amp) ok for Apex AX-14 Stereo Amplifier, please suggest.
- 100W Ultimate Fidelity Amplifier
