100W Ultimate Fidelity Amplifier
Yes, use 22k for R10 and 10k for R6. No need to use cap accross R10. I prefer to use higher value of C7 and C8 to solve the problem of instability. In my AX11 builds I used 100pF for these two caps and have only very small overshoot on square waves. This circuit is AX11 without output transistors so I expect it to work even with 100pF. If you want to play safe use 220pF.
Should i change R10 from 10K to 22K as R2 for minimum output offset?Also could i use a 10p cap across R10 or from T6 collector to base of T3 to improve stability?
This is my simulation with slightly modification.
  • Pre-amp apex mod.asc
Sonal Kunal - thanks! Looks fantastic. :D
https://www.diyaudio.com/forums/attachments/solid-state/560703d1468819884-100w-ultimate-fidelity-amplifier-fh11-
It's very convenient that pin outs for BD139/140, KSC3503/KSA1831, MJE340/350 are the same. Note that on VHEX+ amp, vzaichenko drives a pair of IRFP's with a single KSC/KSA just fine so it may still be suitable to use those drivers. I believe they may have slightly better noise/performance figures over the MJE's.
I have both so it's not an issue - just wondering which will give best performance.
Dear kunal in fh9 how maximum dc voltage.i have 35..0..35 vac trafo .can i use it in fh9 ampl.thanks
