Compression driver to suit RCF HF94 waveguide
Hi Guys
Been researching on parts to built my first horn speaker.
Due to my location, it would be ideal to use parts that I can purchase locally.
Looking into building a 2 way if possible with the above horns crossing over at 600-700hz. Size matters too as it’s for home use. Sensitivity of compression driver need not be high somewhere around 95-97 db or so would do.
Thanks in advance.
RCF ND850/ND950, Radian 745Neo/951, JBL 2452, etc.
Basically any high quality 3" to 4" diaphragm driver will do. The 3" drivers will usually have cleaner treble than 4" diaphragms unless they're Beryllium.
I use the Radian 745Neo with the stock aluminium diaphragm. Great driver.
P. Audio might be a good option in your area. Look for a diaphragm mated with a plastic surround.
-it will go as low as the horn you've selected. (..do NOT go by their "500 Hz" bs in the spec. sheet.)
You may want to read the user reviews on the RCF TT-series by PA folks.
In short: The TT-series have long been among the very best 2-way systems on the market. There are a few Meyer and D&B Audiotechnik products that come close, but those are (even) more expensive.
The crossover frequency of the products containing the HF94 ranges between 700-900Hz.
In my opinion, the APT is anything but better than the HF94.
ooh, necro-posting! 😀 (..as in a long-dead thread.)
The waveguide/horn in the Audioexpress article is NOT in the APT 150S (as mentioned in the article). That's actually a screw-on only design.
Instead it's the SST1, and it's very similar to the HF94 but its off-axis response is a bit more "constant" (..more "straight-sided" waveguide). Not made of Aluminum though, but the SST1 is also considerably less expensive.
Note: you can stress a driver below most of the gain/loading freq. with any horn/waveguide, and it can be less stressful if you do that with the right 1.4" exit driver (as opposed to even a good 1" exit driver). Also 1.4" exit drivers typically have more "gain" lower in freq. regardless of the horn it's used with. This can allow a lower freq. advantage with the HF94, but the horn itself really doesn't adequately support lower freq.s - it's just to small.
