Salas SSLV1.3 UltraBiB shunt regulator
I am upgrading my hole system of power supply for the soekris dam1121.
I already have a UltraBiB for the analog path and just bought an reflector D that was meant for digital part, as these two are separated on the dam1121.
Now I’m interested, from the structional view, is this the right way to go, or should I use the UltraBiB for 5V/300mA digital, and the reflector D for 5V/30mA Analog Domain.
Is the UltraBiB well suited for such a low current draw or wouldn’t the reflector be the better choice.
My Soekris that Salas is referring to (photo in post#14) is the dam1021 while janho12345 is talking about the dam1121. The difference is that the 1121 requires +5V for its digital section and another +/-5V for its "analog". So 3 power supplies in total.
I think reflektor is better for digital.
At least that' s my plan for a DAM1941 I am currently assembling.
Hi Salas,
i finished the build of the positiv reg. unfortunately with an orientation failure of J2, witch i realized after powering up.
Now after soldering a new PF5102 in the correct direction, i couldn´t adjust the output voltage.
Any ideas where i could search?
Best,
Oliver
They make a symmetric from two positives but it would work by showing a virtual ground midpoint. Don't know the compatibility of that in your application. UBiB has a true ground and a real negative section on the other hand that they can also serve down to +/-5V
