Is there only the one i2s input on FiFi Pi from Raspberry or possible to connect another source?
Hi all!
First of all thanks Ian that you since a very long time are developing and selling top notch products for us on such a high level!
Unfortunately I wasn't following all the time, and although I have searched for some time now I cannot find the information I'm looking for. So, please kindly give me some advice if the following is a good thing to go, or if there is a good or better alternative!
I want a "digital transport" for my DAC, which accepts SPdif and AES/EBU as input, and I would like to use a device which can run Roon as and endpoint device, like a Raspberry Pi or the like.
Your new FifoPi "just" does isolation and reclocking, right? So it puts out I²S and the rest to connect to (diy) DACs. What do I need to get SPdif or AES/EBU out?
I am hugely interested in your LiFePo4 battery supply, as I expect it to be an extremely good power supply.
So, to wrap it up:
What do I need to transform a Raspberry Pi into a higher end digital transport? Is the new FiFoPi and some board plus the LiFePo battery supply a good solution? Or should I go with this LiFePo4 battery supply and, for example, the Allo Digione Signature?
Thank you very much for your help!
Matthias
So, to wrap it up:
Matthias
1. iancanada 1*FifoPi, 1*LifiPO4 power, 1*EssController …
2. Crom 1 x FifoPi, 3xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT (and if you have any left: The RPi I2S adapter that enables the ESS controller to be used as an external controller)
3. Oyvind 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
4. Pistollero 1 x FifoPi, 2xLifePO4 power
5. MikeyFresh 2x FifoPi, 1x LiFePO4 power, 2x ESS Controller, 1x dual mono ES9038 DAC, 1x ES9028 DAC, 1x Transformer I/V PCB mini kit, 1x Std I/V stage
6. Randytsuch 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
7. necplusultra 1 x FifoPi, 1xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
8. szczemirek 1 x FifoPi + LifeO4 pure power supply + Transformer I/V PCB mini KIT + I/V STD standard I/V stage
9. casshan 1 x FifoPi, 1 x LifiPO4 power, 1 x Ess Controller
10. zapio : 2 x FifoPi , 4 x LifiPO4 power, 1 x Ess Controller, 1 x transformer I/V PCB mini KIT 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
11. trung224 : 1xLiFePO4 power
12. Sq225917 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
13. passive420: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
14. comickitkit: 9 x Fifopi, 7 x Ess Controller, 7 x dual mono 9038 dac hat, 6 x I/V STD standard I/V stage, 1 x Transformer I/V PCB, 8 x LifePO4 pure power supply, 1 x McFIFO, 1 x McDualXO
15. crymen: 1 x Fifopi, 1 x LifePO4 power
16. ppap64: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
17. Greg Stewart: 3 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 DAC hat, 1 x 9028 DAC hat, 1 x ESS controller extension kit, 3 pks CCHD957 XO Adapters, 8 x 2" u.fl silver-plated extension cables, 5 x RPi metal standoff sets, 5 x LT3042 regulator boards
18. jacklee: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
19. kenlaumm: 1 x Fifopi, 1 x LifePO4 power
20.curryking: 1 x FIFOPi,1 x ES9038 dual mono DAC Hat, 2 x ESS Controller
21. Cerole: 1 x FifoPi, 3 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1*I2S FIFO 2 Kit, 1*Dual XO clock board, 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB
22. Big bird: 1 x Fifopi, 1 x LifePO4 power, 1 x ES9038 dual mono DAC Hat,1 x I/V STD standard I/V stage, 1 x Transformer I/V PCB 1 x ESS Controller
23. wealas: 2 x LiFePO4 power
24. ernesternest: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
25. nounouchet: 3 x LiFePO4 power
26. mjensen: 1 x FifoPi, 2 x LifePO4 power, 2 x ESS Controller, 1 x Dual Mono 9038 Dac Hat, 1 x I/V STD standard I/V stage, 1 x Transformer I/V PCB
27. janho12345: 1x FifoPi
28. Forane12: 2X FifoPi , 3X LifiPO4 pure power supply, 2X ESS controller, 2X Dual Mono ES9038Q2M , 2X ES9028Q2M DAC HAT, 2X I/V STD standard I/V stage, 2X Transformer I/V PCB
29. Joseacm08: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
30. ccliu: 1X FifoPi , 2X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
31. e-yakovkev: 1 x FifoPi, 3 x LifePO4 power
32. minivan: 1xfifopi ,1x Lifepo4 pure power
33. StarLex: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
34. Akasaka: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
35. Yatsushiro: 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
36. luchoh:1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage,
37. nielsek:1xFifoPi, 1x LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage
38. emynet 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
39. cspirou: 1*I2S FIFO 2 Kit, 1*Dual XO clock board(no XO), 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB, 1*RPi I2S PCB adapter, 6*LT3042/LT3045 PCB, 1*I/V STD stage, 1*transformer I/V PCB kit, 1*LifiPO4, 1*McDualXO, 6* U.FL coax (any length), 1*SMT XO adapter package, 1*I2S backdoor kit
40. Brumjam: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT
41. misterdog:1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
42. palmito: 1*FifoPi, 1*LifiPO4 power, 1*ESS controller, 1*Dual Mono ES9038Q2M, 1*I/V stage, 1*Transformer I/V PCB mini KIT
43. flowerpot: Withdrawn (After some consideration decide to withdraw from this GB)
44. _oxygen: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
45. SonofThor: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1x STD standard I/V stage, 1x Transformer I/V PCB mini kit
46. Morde: 1x FifoPi, 2x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1x STD standard I/V stage, 1x Transformer I/V PCB mini kit
47. 1001meier: 1xFifoPi, 1x LifePo4 power
48. deenoo: 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
49. Robs : 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
50. linh0983 : 1xLiFePO4 power , 1xDual Mono ES9038Q2M , 1x FifoPi
51. JoeyDD: 1*LifePO4 power, 1*ESS controller
52. pierantonio: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
53. xaled: 2x FifoPi, 2x LifePo4 power, 2x ESS controller, 2x Dual Mono ES9038Q2M, 2*Transformer I/V PCB mini KIT
54. Duanbui: 1xLiFePO4 power
55. maartn: 1x FifoPi, 1 x ESSController, 4* 7" double-ended silver plated U.FL 178 coaxial cable, 2* ADM715X ultra-low noise LDO PCB (free)
56. syracuze: 1 X FifoPi , 3 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
57. Flyingsparks: 2X FifoPi , 2X LifiPO4 power , 2X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
58. number9, 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage
59. duc985: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage,1X Transformer I/V PCB
60. Lucser: 2 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage and, if completed, 2 x I2S to LVDS HDMI Tx modules as per #2602 post.
61. Stokessd: 1x FIFO, 1x ESS Controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x Transformer I/V PCB mini KIT
62. tomcoppa 1*FifoPi, 1*LifiPO4 power, 1*EssController, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage, 1*transformer I/V PCB mini KIT
63. Blitz: 3xLifePO4 Power, 1*transformer I/V, 1*I/V Standard
64. Chipno :1 x FifoPi , 1 x LifiPO4 power
65. simon dart: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage,1X Transformer I/V PCB
66. kolossos4730: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
67. mksung: 1*FifoPi
68. stavros61:1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
69. cjunkk: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
70. bartb: 1x McFIFO, 1x McDualXO, 1x LifiPO4-pure
71.JimS::1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 2 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
72.KenI:1*FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1*ESS controller, 1*Dual Mono ES9038Q2M DAC HAT, 1*I/V STD standard I/V stage
73.kvl: 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1xDual Mono ES9038Q2M ,1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
74 secanbj 1*FifoPi, 1*ESS controller, 1xDual Mono ES9038Q2M ,1*I/V STD standard I/V stage
75.deanoUK :1 x FifoPi 768KHz 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M
76. cubano: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage
77. Hellokitty123: 1X LifiPO4 pure power supply / 1X I/V STD standard I/V stage 1X / Transformer I/V PCB mini KIT
78. nori1000: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, Or 1x Isolator II, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT,
79. Rowli: 2 x LifiPO4
80. Sidiropa: 1*LifePo4 power
81. stephengrenfell 1*FifoPi, 1*LifiPO4 power
82. Mindfunk: 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
83. tanelip: 1*FifoPi, 2*LifiPO4 power
84. sbiswas-1: 1 x McFIFO, 1x McDualXO,1x LifiPO4 pure power supply
85. Jjazz: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
86. s666foto: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
87. niner: 2 x LifiPO4
88. maui: 1 * FifoPi, 1 * LifePO4, 1 * I/V STD standard I/V stage, 1 * I/V STD standard I/V stage emty PCB, 4 * 2" U.Fl wire double ended, 1 * CCDH957 XO adapter kit lot of 2, 1 * ESS Controller, 1 * ESS controller extension kit, 1 * dual mono ES9038Q2 dac, 1 * LT3042 low noise regulator PCB
89. ofswitched: 1 * FifoPi
90. neslo: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
91 AlanElsdon:1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
92 cv: 2 x FifoPI
93. chi0001: 1 x FifoPi, 1 x LifePO4 power, 2 x 2 x Ess Controller, 1 x dual mono 9038 dac hat, 1X I/V STD standard I/V stage, 1 x transformer I/V PCB minit kit
94. cps3113:1 X LifePO4 pure power supply.
95. ilgavro 1x fifopi 2x lifepo4 power 1xesscontroller 1x dual mono 9038 da hat 1 x std standard I/V stage
96. ykharlamov: 1 x LifePO4 power, 1 x McFIFO, 1 x McDualXO
97. M_Balou: 1*FifoPi
98. yaboin: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage, 1*transformer I/V PCB mini kit
99. stenachio: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage
100. ilraffa 1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 da hat 1 x std standard I/V stage
101. ermine22. 2X FifoPi , 1X LifiPO4 power , 2X ESS controller, 2X Dual Mono ES9038Q2M, 2X I/V STD standard I/V stage
102. cesare2K. 1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 da hat 1 x std standard I/V stage
103. artmic: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*transformer I/V PCB mini kit
104. lugo689:1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 dac hat 1 x std standard I/V stage
105. tods:2x fifopi, 1x lifepo4 power, 1 x esscontroller, 1 x dual mono 9038 dac hat, 1 x std standard I/V stage
106. copper31: 1 x FifoPi, 1 x LifePO4 power
107. plsm: 1*FifoPi, 1*ESS Controller, 1*dual mono 9038 dac hat
108. Gabry63: 1x fifopi 2x lifepo4 power 1xesscontroller 1x dual mono 9038 da hat 1 x std standard I/V stage
109. dynpro100: 1 x I2S to PCM converter board, 1 x Finished TPS7A4700 low noise regulator board, 1 x RaspberryPi I2S adapter PCB/connector package
110. sp502: 1 x McFIFO, 1 x McDualXO, 1 x Finished TPS7A4700, 9x U.FL. coax cable (4",7",12"), 10x U.FL. sockets, 1x SMT XO Adapters KIT, 4x 767KE-ND
111. Pinnocchio: 1x FifoPi, 2x LifePO4 power, 1x ESS Controller, 1x Dual Mono 9038 DAC HAT, 1x I/V STD standard I/V stage, 1x Buffalo I/V Adaptor
112. hiroyuki.t: 1X FifoPi , 1X LifiPO4 power , 2X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
113. rudra: 1 x FifoPi, 1xLifePO4 power, 1 x RaspberryPi I2S adapter(transmitter)
114. jp2017: 1 x i2stopcm
115. stones: 2 x FifoPi, 1 x LifePO4 power, 2 x Ess Controller, 1 x ESS controller extension kit, 2 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x I/V STD standard I/V stage empty PCB, 1 x transformer I/V PCB mini KIT, 2 x LT3042 low noise regulator PCB, 1 x I2S to PCM, add UFL cables if needed
116. adelias 1 x FifoPi, 1 pkg CCHD957 XO adapter kit, 3 x 2” double-ended silver plated U.FL coaxial cable
117. ngocpham: 1xLifePO4 power
118. marcus1: 1xLifePO4 power
119. vanofmonks 1x FifoPI, 1x Es9028 Hat, 1x I/V, 1x ESS
120. Val33 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
121. cristianr: 1xLifePO4 power
122. triodehunter: 1x McFiFo, 1x McDualXO
123. TirNaOg: 2 x LifePO4 power
124. Dave S: Nothing
125 spm FifoPi, LifiPO4, ESS controller, Dual Mono ES9038 HAT, I/V STD and Transformer
126. quick16 2 x FifoPi
127. mige0: none
128. fm804: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage, 1 x Transformer I/V PCB mini KIT, 1 x I2S to PCM converter board V2.0, 5 x 6" double-ended silver plated U.FL coaxial cable
129.AcDcMan1: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
130. APK : 1 x FifoPi , 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
131. miklau: 1 x FifoPi
132. Aronier : 2*FifoPi, 2*LifiPO4 power
133. JimmyThinker: 2x FifoPi , 1x ESS controller, 1x ES9028Q2M DAC HAT, 1x I/V STD standard I/V stage, 2x New RPi I2S adapter, 3x U.FL coax (4”), 3x U.FL coax(6”)
134. BachAudioDK: 1 x I2S to PCM, 2 x OPA861 I/V converter
135. Jorgen E : 1 x LifiPO4 pure power supply
136. Patjr : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
137. markhw4: 1 x McFifo, SMD XO adapter kit, 4* ADM715X ultra-low noise LDO PCB (free)
138 ollux: 1*FifoPi, 1*LifiPO4 power
139 TioFrancotirador 1*FifoPi
140 Tml: 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
141 iggy111: 1x McFiFo, 1x McDualXO, 1x LifiPO4 power
142 kirks: 1 x FifoPi , 1 x LifiPO4 power, 1 x ESS Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
143 prohvesor: 1 x LifiPO4 power
144. derekv: 1 x FifoPi, 1x Dual Mono ES9038Q2M DAC HAT, 1 x Transformer I/V PCB mini KIT
145. aguaazul: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
146. Supersurfer: 3*FifoPi, 2*LifiPO4 power, 1*EssController, 1* Dual Mono ES9038Q2M DAC HAT, 6* 4" double-ended silver plated U.FL coaxial cable, 4* 7" double-ended silver plated U.FL 178 coaxial cable, 12* SMT U.FL socket, 2* RaspberryPi I2S adapter PCB/connector package, 4* ADM715X ultra-low noise LDO PCB (free), 1* I/V STD standard I/V stage, 1* CCHD957 XO adapter kit lot of 2, 1* ESS controller extension kit, 1* Package of OPA1622 adapter PCB kit lot of 5, 1* 2” double-ended silver plated U.FL coaxial cable, 3* 2.5mm metal standoffs for RPI lot of 4 sets, 2* LT3042 low noise regulator PCB, 2* I/V STD standard I/V stage empty PCB
147. CAAD: 1* FifoPi, 4* ADM715X ultra-low noise LDO PCB (free)
148. atom6422 : 1 x FifoPi, 2 x LifiPO4 power, 1 x EssController, 1 x ES9028Q2M DAC HAT, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage, 2 x transformer I/V PCB mini KIT, 1 x OPA861 I/V converter, 1 x I2S FIFO II (I2S) KIT, 2 x Dual XO II Clock Board without XO and socket, 1 x FIFO II isolator board mini KIT (finished), 1 x FIFO II isolator board mini KIT (unfinished), 1 x S/PDIF Interface Board for FIFO II, 1 x I2S backdoor KIT for S/PDIF board, 5 x Battery Management board PCB, 2 x Package of Universal SMT XO Adapters KIT lot of 5, 3 x Anti-vibration screw grommet set(767KE-ND), 4 x ADM715X ultra-low noise LDO PCB (free)
149. johnyn: 1xFifoPi, 8 x 4" double-ended silver plated U.FL coaxial cable
150. acg 8 x LifePO4 power
151. RonR: 1*FifoPi, 1*I2S to PCM, 1*ESS controller, 4*U.FL coax (4”), 4*U.FL coax(6”)
152. Raj1: 2 x LifePO4 power
153. alazira1: 3 x LifePO4 power
154. malcox11 1*FifoPi, 1*LifiPO4 power
155. Emi90: 1xLifePO4 power
156. 1x FifoPi, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
157. diyiggy : 1*FifoPi
Changed 146. Is there a discount for big spenders?😀
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
111. Pinnocchio: 1x FifoPi, 2x LifePO4 power, 1x ESS Controller, 1x Dual Mono 9038 DAC HAT, 1x I/V STD standard I/V stage, 1x Buffalo I/V Adaptor, 1x ESS controller extension kit, 3 pks CCHD957 XO Adapters, 1x 2” double-ended silver plated U.FL, 1x 4” double-ended silver plated U.FL
127. mige0: none
Edit # 111
92 cv: 2 x FifoPI
127. mige0: none
Edit # 111
92 cv: 2 x FifoPI
127. mige0: none
Edit # 146
92 cv: 2 x FifoPI
127. mige0: none
Edit # 146
55. maartn: 1x FifoPi, 1 x ESSController, 1 x ESS controller extension kit, 4 x double-ended silver plated U.FL 178 coaxial cable, 2 x LT3042 low noise regulator PCB (free)
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
127. mige0: none
83. tanelip: 1*FifoPi, 1*CCHD957 XO adapter kit
92 cv: 2 x FifoPI
127. mige0: none
edit # 83
92 cv: 2 x FifoPI
127. mige0: none
edit # 83
8. szczemirek 1 x FifoPi, LifeO4 pure power supply, Transformer I/V PCB mini KIT, I/V STD standard I/V stage, CCHD957 XO adapter kit
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
127. mige0: none
158. AndyN: 1x FifoPi, 1x ESS Controller, 1x Dual Mono ES9038Q2M DAC HAT, I/V stage board
Edited #158
92 cv: 2 x FifoPI
127. mige0: none
158. AndyN: 1x FifoPi, 1x ESS Controller, 1x Dual Mono ES9038Q2M DAC HAT, I/V stage board, 1x (or 2 for dual mono?)Transformer I/V PCB mini KIT
92 cv: 2 x FifoPI
127. mige0: none
price estimates are here: Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Final pricing with documentation to follow.
Very exciting with the upcoming group buy. So if one wants to build a complete DAC then the followings will be needed, correct?
A1. FifoPi 768KHz I2S/DSD/DoP FIFO with isolator and dual XO, estimated $99-(Special price for this GB, regular $135-)
A2. LifeO4 pure power supply with 5 output rails (no battery), estimated $199-
A3. ESS controller, estimated $39-
A4. Dual Mono ES9038Q2M DAC HAT, estimated $85- (OR A5. ES9028Q2M DAC HAT, estimated $49-)
A6. I/V STD standard OPA I/V stage, estimated $35- (OR A7. Transformer I/V PCB mini KIT, estimated $19-)
A8. ESS controller extension kit, estimated $12- (OPTIONAL?)
A9. Package of dedicated CCHD957 XO adapter kit lot of 2, estimated $8.9
A10. Package of OPA1622 adapter PCB kit lot of 5, estimated $9.8 (OPTIONAL? Is this for A6?)
A11. 2” double-ended silver plated U.FL coaxial cable, estimated $2.8 (HOW MANY?)
A12. 2.5mm metal standoffs for RPI lot of 4 sets, estimated $2.9 (HOW MANY?)
In addition one will need to order the rPi which I think is the Raspberry Pi 3 Model B+?
URL: Raspberry Pi 3 Model B+ - Raspberry Pi
And if one choose Transformer I/V (A7) then which transformer should one order?
And if one choose A9 then one will need to buy the XOs separately.
I'm sure Ian's doc will have these info but feel free to chip-in. Thanks.
Edited #49
49. Rrbs : 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
127. mige0: none
Edited 6
6. Randytsuch 1 x FifoPi, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1x transformer pwb, 1 x xo adapter, 1x opa adapter, 1x standoff kit, 2 x I/V STD standard I/V stage pwb, 4 x lt3042 pwb
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
127. mige0: none
+1
What do I need to order to go from ES9038Q2M DAC HAT to the best possible RCA (L+R) output? Will the I/V STD standard OPA I/V stage be sufficient or do I need more?
Hi Ian,
I would supply some of your stuff with your new LIFEPO4 battery management board, so I would know what rails I need.
I have to supply:
1 x FIFOII
1 x Dual clock board (without oscillator, external clock)
Can I supply all 3 boards with a single 3V3 rail? In this case, have I to remove any regulators from the boards?
Or I need 6V6?
I have to supply:
1 x FIFOII
Or I need 6V6?
Hi guys,
Sorry for the bit delay. I’m working hard and didn't take too much time listening to music🙂. Here are the most recent update of GB2018 new items and the estimated prices. Finial pricing will be released very soon.
A13. LT3042 low noise regulator PCB, free
A14. I/V STD standard I/V stage empty PCB, free
The cost of LifePO4 power supply was a bit higher than I expected. As an audiophile DIYer, I understood how important to make the price more reasonable. However for small production such big PCB board assembly with so much components on both side, that’s really the best I can do. And also, the weight of that board will be over 350g. Once a package is greater than 500g, the Canada Post shipping would be double. So, to ship it outside Canada and USA, the estimated shipping could also be higher. Please do take a consideration before you make the decision.
Ian
Ian, is there a thought that you could give the main life boards a daughter board if someone wants to have 10 rails instead of five ? I would guess that all the expensive components need to be there only on the master board while the slave is just an expansion ? Currently I would need two boards to really give all the stages of my full wavioIO-fifoII-dual-mono-BIII individually battery power...
Hi Ian,
I have to supply:
1 x FIFOII
Or I need 6V6?
You can power either of them with 3.3V rail. They work with the no-board regulators. However bypassing those regulators can reduce internal impedance more.
Ian
Ian
Thanks for the reply.
Can you please tell me which regulators and how to bypass them?
Thank you
Andrea
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
