New FIFO buffer for RPI/SBCs
No further details at this point . We will give more info as we advance
Im curious.. will Allo solve its heating issues with Katana. I had seen a heating issue of your digione signature in computer audiophile thread.
to be honest... whenever I leave my allo products turned on.. I am a bit worried that my apartment may catch fire... (even with my replaced unit)..
any quality assurance measures from allo's part? we need a feedback from you especially when we buy the upcoming LPS..
Hi Guys,
In Katana documentation I read that the Rpi gpio pin that are used are pins 3,5,35,12 and 40. Is that all for signal?
What pin is used by isolator for power? 2? 4? or both?
What pin is used by isolator for ground?
I would like to connect pi to isolator using short wires to fit my casing model.
Thank you for your help.
Terry
Yes the pins of Katana are correct , for power isolator uses either/ both 2/4 (shorted internally) and all Gnd pins and also shorted so you can use any..
