A Loftin-White style SE with EL34
I'm investigating the possibility of doing a LW style amp with an EL34 for the output stage. I have a pair of Transcendar 5k:8/4 7W OTs that are somewhat under utilized in their current project as well as an Antek AS-1T200 for power. The OT's can only handle 75mA, and 5K is a bit high for the 375v voltage in most datasheets (For SE triode), but going up to 400v looks like a good fit at 5k for about 7W. With the primaries in series the Antek should do about 565 @ 150mA. I'm thinking I drop about 140v across the cathode circuit to power a single triode stage (either ECC99 or E88CC) with a choke load. TubeCad has an article I pillaged all the basics from:
Loftin-White Amplifier
Attached is a screen shot of my current plan. About 60ish mA of bias current (max), a 3k cathode resistor (Dissipates a hefty 6W) and a 1k 2W bias pot (currently set to 350 ohms in the screen shot). The idea being that the voltage drop across the pot (trim-able) plus the drop across the DCR of the choke (fixed with bias current of the preamp stage) sets the -Vgk at the grid. The EL34 cathode current minus whatever gets diverted for the preamp stage sets the drop across the 3K, which becomes the preamp stage's supply.
I'm still shopping for a choke. I suspect I'll end up with a Lundahl from the LL1668 series. There's an outside chance I try a CCS version but for now I like the idea of trying a choke.
I didn't start out planning a DC coupled amp, it's just that the parts I have seem to work out just right. Thoughts?
The idea looks good.
I will not take the time to check your DC levels.
That circuit should work if you get the DC right.
. . . But I did notice one thing:
You put R13 on the wrong side of R10. Grid stopper resistors belong connected directly to the grid tab of the tube socket, with Nothing else connected to the grid tab (otherwise the grid stopper can not do its work).
Here are some further insights from simulation.
One thing that worried me was burning up the potentiometer under some combinations of settings. While a pot that can handle some power is necessary it looks like a 2W should be OK. The first two attachments show dissipation when the pot is varied between 100 and 900 ohms with 0, 680, and 1500 ohms of choke DCR. The DCR matters because the choke will drop some of the bias voltage - a magical 0 ohm choke would put the greatest burden on the potentiometer.
The 4th screen shot is anode current over the same spread of values assuming a 680 ohm choke. The range looks good.
Last are the DC levels at the grid and cathode along with Anode current.
Just a quick check in: I wired up my PT as a test, and I’m glad I did because with no load my B+ came in a bit lower than expected. Under load it will be even lower than that so I think I’ll be starting from about 520v rather than 560. I’ve ordered a few different sizes of cathode resistor so I can tune a bit. I also placed an order for 100H inductors. The dcr is a bit higher than I’d hoped but it really only matters in the preamp tube fails or is removed and I expect it would only change the bias by about 20%. I’m going to try and get a prototype wired up (sans chokes) in the next week or so.
That's good to hear. How long have they been in service? It looks like you derive your -Vgk from the voltage drop across the inductor's DCR. The preamp is running at 8.6mA so you have a ~24v drop from the GU15T's cathode to it's grid. Did you have to tune R9? Where did you buy your inductors?
PRR,
Good printed example. Thanks!
A lot of leading research and development was also done by Radio Amateurs.
Then there was Mr Heil, the inventor of the Heil air motion tweeter. He had plans for an FET, but it was before there was the solid state technology to support it. His on-paper FET was before Bell Labs came up with the Point Contact Transistor.
"Those who do not know the history of early inventions are bound to repeat them." (stolen and re-worded by me)
Ok! Prototype is done! Pictures attached. Sounds nice so far but I’ll do some more demanding listening test today. Currently there is no feedback and the e88cc cathodes are unbiased. I’m running the outputs cool for now too, about 20W.
