Sony vFET Amplifier Part 2
Happy New Year to all.
Just got back to using the VFET2
From my last post Changed C1,C2 to 220uF and C3,C4 to 50uF (2 100uF in series) as suggested and didn't hear a putt putt (1 beat per second low frequency}
usingTea Bag boards and Botte changes
Now I have a problem in one of my channels (call it Channel A) . I turn on the power and bias current is about 2A and DC offset is 600mV. I can lower bias and offset by trimming P1, P3 and P4 - P2 seemingly doesn't have any effect. After an hour or so of tweaking I have 1.25A of bias and 50mV offset. Left amp on for 3 hours - everything stable. Channel B is at 1.25A of bias and 15mv of offset. Turn off amp.
Next morning Channel B is1.25A of bias and 15mV upon turning on the power
Channel A has reverted to 2.25A bias and 550mV of offset - which I can adjust in about an hour to 1.25A and 50mV offset.
Turn off power - high current and offset return to Channel A 😕
Thoughts anyone?
Best and thanks
Bob
I would start changing those TL431 critters and rebiasing
maybe putput situation drove semi-berserk one of them
Could you please explain the purpose of resistors R41 and R42 in the “Sony VFET Amplifier Part 2” article. In “The DIY Sony VFET” article from 2016 the same resistors are designated R23 and R24.
These provide a DC connection from the output of the front end to the
input of the output stage. As you see, they are bypassed by capacitors
which hold the bias voltage (since we want low AC impedance for driving
the output stage). AT DC we don't need such a low impedance, and the
resistors allow the front end to adjust the output DC.
So if we used similar resistors across the corresponding capacitors in the F4, could we then eliminate the offset adjustment?
I am building a BA-3B and want to use the latest VFET front end, hence the questions.
Graeme
I have changed the TL431s.
Then back to basics.
Lifted R11 and R12 on one side. Adjusted P3 and P4 to get 1.8V across R25 and R26 with approximately 10mV offset at R20. Turned off power and then checked next day. Everything returned to original measurements so I think this is stable.
However with R11 and R12 still lifted I used P1 and P2 to set voltage at R1 and R4 so that I know VFETs are shut down. I can get -14V at R1 but only can get a few mV at R4.
Next move ???
Best and thanks
Bob
in this moment , all what's important of entire amp is just two voltage regs made of TL431 ........ so , it's simple - think of them as plain small regs and nothing more
check surrounding resistors , same as loading of regs
are R4 and R5 still OK ....
are C5, C6 OK .........
are R41 , R42 OK .........
are Z3, Z4 OK ..........
from ZM
Visually nothing smoked
Measuring in circuit
C5,C6 222uF
R5,R6 8.5k
R41. R42 15k
Z3 18k, Z4 =15k not sure that's what I should be measuring but wanted to check that there wasn't an open
R4 220
Thanks ZM
Bob , R4 was a typo , I meant R5 and R6
whatever ....... as I said - you're troubleshooting "just" two , in fact - just one reg circuit
change everything in that reg circuit if needed , don't fret about reason why something broke ..... so - lift resistor leg and measure it , check pot ( as D. said) , replace TL again .... replace all mentioned parts , but don't let funny reg to spoil your fun
OK the latest
replaced P1 ( thanks Dennis ) it was flaky
pulled and checked R5,R6, R41, R42 they are OK
replaced c5,c6
replaced z3.z4
replaced the critters
now no negative on R1 and about .5V on R4
I did some stuff on bottom of board so I need to check everything - something could be backasswords or not soldered correctly - will let it rest for a day or two
Thanks guys
