Meat grinder attachment for the KitchenAid stand mixer.
I am commencing head smacking as we speak. I really ought to have bought both a lot sooner.
M2x pcbs from the diyaudio store at 30% discount!
I jumped on the deal as well!
Meat grinder attachment *snip* I am commencing head smacking as we speak.
Have things really gotten that bad in the USA? 😱
Lift Stand or Tilt Head?
I bought the Kitchen Aid KP26M1XES 6 Qt. Professional 600 Series Bowl-Lift Stand Mixer, but haven't purchased any attachments yet.
Some of the reviews for the meat grinder were less than favorable, as it is made of plastic and several people had them split.
Same mixer. More than 50% off on Black Friday.
The attachment is partly aluminum and partly stainless. The only plastic is the shaft bushing. Works better than expected. Does as good a job, if not better than, the Porkert manual one.
Metal Food Grinder Attachment KSMMGA | KitchenAid
Well, it's close, here in California, at least. 🙁
I assume it's not that bad up in the Great Frozen Wastes of Syrup Land where Cal hails from 🙂
… Syrup Land…
… is at the other end of the country. Cal & i are in Cheech & Chong Land.
dave
Ohh, man. Flashback to a small group of us burnouts, sitting waay in the back of the school bus, reciting these bits to each other, over and over...
OK, dig deeper into those memories......
Don't crush that dwarf, hand me the pliers.......I've got right here in this car, for your trans-Atlantic driving pleasure, this fully hallicrafted Sea-Master short-wave radio........Can I get Duluth on it?......Duluth, bucko! You can get Tierra Del Fuego!
Sorry for the brief detour to 1969....now returning to our regular time zone.....
I still listen to Firesign Theater... How can you be in two places at once.. is probably my favourite!
Antelope Freeway, 1/4 Mile... 🙂
Yes! I remember Bozos nearly verbatim. Had occasion to hear the original Quad mix recently, it's great fun!
harman Kardon Onyx mini.... i used to have one and gave it to my brother. Now i only have a sony xb20..... but i miss the Onyx. i has great midrange for a portable bluetooth player of this price range (even in absolute). couldn't resist ordering one again... for computer speaker use. Too bad they are phased out!
I finally bought a 2.5 amp power supply and a 2.5" external hdd enclosure for my raspberry pi.
I've been busy lately but I've managed to find some time this week to setup a rasberry pi as a wireless access point using this tutorial:
Setting up a Raspberry Pi 3 as an Access Point - learn.sparkfun.com
I desoldered the factory SMD-sized antenna and I soldered a RP-SMA male plug onto the main board.
No need to say what it will be used for. NAS and access point for sharing wikipedia to ipads/tablets.
I also bought a bottle of wine for NYE celebrations. Le Chat Noir M Pierre Pinot Noir.
Having ordered the wrong type first time around, I finally received a proper 3.5" touchscreen for my Raspberry Pi model 3 B+. My project, if I can figure it out, will be a multichannel music player with a miniature "quad scope" display in the spirit of the old Pioneer, Sansui etc. quad receivers. Lots of reading ahead for this Linux noob, which will hopefully also be a springboard for weaning off Windows in time for their dropping support for 7 in 2020. We'll see...
Lovely wine!
I still vividly recall how hazy I felt leaving a wine tasting at the Black Cat vineyard in Germany, c1995.
The Eizewine is something else
1x New 12V 10Ah LiFePO4 Lithium Rechargeable Battery same size as 7AH 9AH last long | eBay
3x 5A 12V Solar Charge Controller CMP03 Waterproof Solar Regulator Load on 24 hours 603338689925 | eBay
2x 1PCS DC DC Step Up Converter Boost 60V 48V 36V 24V 12V to 18V 12V 9V 5V 3V AU 654936398993 | eBay
1x New 30 CAL Ammo Box Steel Ammo Can Hunting Ammunition Military Tool Box | eBay
Put them all together + with a rasberry pi and an antenna sticking out the top and you've got yourself a whole bunch of post-apocalyptic entertainment right there doggo!
It doesn't hurt to have a few spare parts either, hence why I got 2 or 3 of each part.
HOT SALE 12V DC 10A 120W Regulated Switching Power Supply for LED Strip Light | eBay
Bought for running all my "smart' 300 led RGB strips. (and 365nm UV's).
Switching fet and output diode devices were without thermal compound
and not touching the heatsink ... i knew this before buying - YouTube
Schematic and all else one would have to know !!!
checked soldering , re-positioned power components (used thermal compound) .
My 8$ smps does 10A wile running cold. Good deal.
Also , 16ft 5630 SMD 300LED Waterproof Cool White Flexible LED Strip Light Super Bright 14834115021 | eBay
Light up whole big rooms for 9$. 120v individual LED lighting has cheap
(individual) poor PFC convertors . 12V system is 3x more efficient.
150$ = solar panel + gel cells + 2-3K rgb or white led lighting - no need
for the power company !!
os
os
Some more bakelite terminals for quick valve projects!
8pcs 10-pin Bakelite Terminal Tag Turret Strip T14 USSR New Old Stock | eBay
A little Christmas present to myself!
- Member Areas
- The Lounge
- And what did we buy today?
