Transformer wiring
I'm having some difficulty understanding the wiring diagram on this transformer. For the input, it looks like the BLK is 0 - RED is 115V and GRY is 0 - ORG is 115V. My assumption would be that the BLK and GRY go to the neutral side, while RED and ORG are the Hot side.
What confuses me is the label at the bottom --> N: YEL/GRN. To me this looks like it would for the shielding to ground, so why is it labeled with 'N'? Also, for 115V I would simply connect the BLK and GRY in parallel to neutral, and the RED and ORG in parallel to Hot, right?
One more question: The output on the transformer is labeled ORG 24V and BLK 24V. The input on my power supply has 2 2-terminal AC25V inputs. So, I would think that both ORG go to one of the input pairs, and both BLK goes to the other input pair. Correct?
The transformer has two independent 115V primaries and two independent 24V secondaries.
The green/yellow wire is for a ground connection.
You have correctly described how to connect the two primaries in parallel to work on 115V.
Not sure how the secondaries should be attached to the terminal strip on the power supply board since I can't see any helpful markings. Unlikely to be as you describe. I would have to be able to inspect the board closely from the track side.
Could post more information on the power supply board?
My guess would be that the two blacks go to the two inner terminals and the two oranges to the two outer terminals, but that is in need of verification!
We need to see the track side of the board or the schematic of the power supply board
I've attached the basic circuit. Looks like the secondaries should be connected (from top to bottom of terminal strip in post #3)) - orange, black / orange, black.
Yes, it would appear that the two blacks go to one rectifier and the two oranges to the other!
Sorry for my diversion, but I think we've reached our destination! 🙂
And, you were right from the start! Shucks!
I got it working. Thanks for your help. It sounds great, I'm going to let it burn in for a few hours before I make any judgments. Even without an enclosure (on an open test-bench) there is zero noise. I'll be glad to trash the Schitt Magni 3 it will be replacing.
