If you use 18V rail voltage and lowish bias try to use one pair of power transistors.
Please take a look at the bias settings table, those power transistors to perform in Class A, to bring out the sweet point they need certain bias level. Sometimes better to use only one pair than two. For example, if the transformer only can handle low power etc.
Prasi: the 2SA970 transistors need to be rotated 180 degrees?
Thank you.🙂
Here is my progress, please do not laugh at my input cap solution.
I ordered Clarity caps but they are huge so I use these Russian type, the same problem with the 1000uF 16V Elna Silmic they just too big. 😱
Thank you.🙂
