EUVL, I haven't decided yet as to use bipolar or mosfet output devices. I would certainly like to try mosfets again, but I just don't know if they have the capability that I need. My design goes back 49 years when I first built my first complementary symmetry BRIDGE power amplifier (a motor drive) at over 2000 Watt rating (I was shooting for 50V-50A with a 1 ohm load). I have improved it over the decades, of course, but I have no commercial product of mine that is constructed that way. It's about time!
Also, I am again interested in wire and cable differences. How could these wires be audible? No! Don't try to tell me here, I KNOW that the answers to this question are not here.
That’s pretty clear, and is also what I find interesting about the more strictly academic types; if I can’t explain it, then it simply doesn’t exist. Oh well, is humorous how someone such as myself with a limited background in applied physics can observe basic differences every time, yet...
I’ve gotten to the point myself, that to make too much fun of it is nearly akin to attacking someone for their religion or something; seems cruel, right(?)
So is the new amp something that would entertain the use of vertical mosfets perhaps?
I respect any restraint you may wish to maintain around the discussion of new designs, so I won’t be offended or anything if you won’t answer that.
Another Newtonian heard from (again)
Suit yourself, the comparisons of the likes of Peter Belt and Geoff Kait to Galileo and Copernicus have also become quite tiresome and trite.
Yet the folks at CERN, LHC, LIGO, etc. don't. Funny how that is.
Yes..............Indoctrination NOT education ..........Yes, you need a very closed mind to do world-class physics.
Not enough measurement effort was made public. We have no idea what measurement setup at any precision shows or fail to show observed difference. It is very difficult for people who can not reliably hear a difference to attempt measurement.... Oh well, is humorous how someone such as myself with a limited background in applied physics can observe basic differences every time, yet....
Hey John,
I hadn't looked into those latest parts, what do you mean they work on the air?
Cheers!
Howie
Some kind of field effect affecting the local environment and all within it, similar to wine/cognac being effected by John's coaster or my filter material applied around the top of the stem of a wine glass.What Scott took apart and can't figure out is: A foil coated with a quantum resonant material that changes the properties of the atmosphere nearby it.
It appears to change a number of properties of the acoustic space, for example. It is the COATING on the aluminum foil that makes the difference. Buckytubes are still used with earlier Bybee devices and require connection to the AC, etc.
I have an alternate method to JB where I apply an amount of my material at each corner apex of the room (8 pieces) and this sets a tunable 'tone' (lack of 'tone' actually) to the room such that the room essentially disappears.
A friend recently commented on my room/system sound quality and remarked 'where are the room treatments ?'....ok two leather comfort chairs and a carpet square but elsewise nothing special is required to achieve unusually clean, clear, fun and perfectly intelligible sound when the room is 'treated'.
The structure and by extension the air in the room can be affected and effected perfectly easily, this has been going on since the beginning of time and right under our noses.
Dan.
Dan, you appear to be doing something similar to what Jack is doing, and also some German guys as well. I can't duplicate it, but I do, as well as my colleagues, notice the differences that do seem to be a 'field effect' or something similar. By the way, my IPC Energizer still seems to make my cognac taste better.
Some kind of field effect affecting the local environment and all within it..
Presumably, that would include John's brain?
So proving a form of Poe's law?
No............(Well ........... maybe?)
This:
The Structure of Scientific Revolutions - Wikipedia
Along with:
The Act of Creation - Wikipedia
It might change the brain, but not just mine, if it does.
If it changes the atmosphere, as you say, how could you be sure what else it might change? Or if what is changing is your perception more than anything else? Or, what if it causes cancer, or tooth decay?
If such a thing existed, it would probably do much more than merely make stereo systems sound better in a room. That might be the most absurd part of the claim.
If such a thing existed, it could and likely would be quite dangerous to be around.
Fortunately, the chances of it existing at all would seem to be pretty much zero. Still might not be healthy to be around depending on whatever is in it.
FUD .If it changes the atmosphere, as you say, how could you be sure what else it might change?
Mind control FUD .Or if what is changing is your perception more than anything else?
Mortal FUD .Or, what if it causes cancer, or tooth decay?
Does not exist FUD .If such a thing existed, it would probably do much more than merely make stereo systems sound better in a room. That might be the most absurd part of the claim.
Alarmist FUD .If such a thing existed, it could and likely would be quite dangerous to be around.
NIH FUD .Fortunately, the chances of it existing at all would seem to be pretty much zero. Still might not be healthy to be around depending on whatever is in it.
LOL.
Dan.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
