Global Warming/Climate Change hoax
You need to look at the whole world, four producers account for 55+% of beef production.
Or do we need to look at beef consumption per capita rather than production, in which case the USA is 4th instead of first.
World Beef Consumption Per Capita (Ranking of Countries) - Beef2Live | Eat Beef * Live Better
China is way down the list at number 47 for per capita consumption, but has the fastest growing beef industry in the world.
World Beef Production: Ranking Of Countries - Beef2Live | Eat Beef * Live Better
At over half the production of the USA, it will become the largest producer in the near future.
Let's assume for this argument, that it's not man-made. If we know, from empirical evidence that the sea water is warming and more importantly rising, then take strategic actions to mitigate the effects. If you can't stop it from happening then meet the challenge head on! I'm not a climate guru, but starting to build seawalls in the most vulnerable places, relocate from low-lying wet-lands areas, elevated roadways in lower areas seems like places to start. Maybe stricter building codes in hurricane prone areas, etc. etc. These are mitigating steps, since there appears to be (at least in this group) no consensus as to the real cause. If you understand the cause we may be able to reasonably engineer a solution, or change a few habits to help ward it off or slow the progression.
Be sure it won't happen over night, nor is anyone suggesting that it will. It won't be cheap, nor easy either.
I've found out over my life time that almost all projects are more successful if carefully, and methodically planned. Ignoring a problem does not magically make it go away. :)
In other words, there is nothing humans can do to change / reverse the global temperature rise and fall. Got it.
I think it is important to compare the relative greenhouse gas emissions and land and water damage caused by American humans and farm livestock, per unit of useful food. To prioritise climate saving actions we need to know this.
I've heard all sorts of greenhouse gases but am curious what your answer is. What is your answer of greenhouse gas that you knew when you posted the above quote (not something you are going to look up now)?
Well the total consumption by the USA is way ahead of the next. To improve the ratio needs either fewer cows in the US or more Americans. You decide. :D
Total consumption per capita of USA is fourth, not first.
I vote for fewer Americans. Then again I realized in 1968 that there were too many people already in the world.
Interesting note, discounting immigration, the population of the USA has been decreasing since the early 1970s.
" In fact, overall U.S. fertility is slightly less than replacement level and has not exceeded replacement level since 1972."
U.S. immigration, population growth, and the environment - SUSPS
Immigration constitutes the growth rate of the USA.
