DIY I2S to simultaneous converter PCB
Any tips on soldering the surface mount components onto the board? I am not confident I could do it especially.
Use a good quality flux - Amtech NC-559 is up there with the best. Beware of fakes, this stuff is only made in the USA. Don't buy from china for this particular product.
Use a soldering iron that you can dial in the temperature exactly - with a small chisel tip I have it set at between 300 - 330 degrees celsius.
Use lots of adequate lighting.
Use a multicore 63/37 or 60/40 solder with a diameter of no more than .5mm
There are heaps of instructional videos on youtube.
That is the way I do it:
Use magnifying glasses.
I put a little solder on the PCB pads first.
I glue a match to the component's top to better handle it.
I place it perfectly on top of the soldered pads.
I proceed to solder pins and pads together with a little downward pressure on the pins or legs of the part. The opposite extreme corner legs first, to have a fixed position. Then it is safe to solder individual legs as they will not move...
I hope this helps.
Good luck,
M.
Sure, but my mess of a dac might be a good example of how not to do it...:p
