Burning Amp BA-3b (Balanced)
I got a matched set of 24 FETs from a well known source and the boards from DIYAUDIO. All the parts are from Digikey and hificollective, all top parts. The amp is exactly as per schematic.
The gain board outputs 44v peak-to-peak which goes into the bias board then into the two output boards. The output on the output boards is also 44v p2p which is not much considering the rails are on 80v dc. I was expecting 60-65v p2p. I suspect something is wrong.
Also, isn't the output stage a buffer (and hence no voltage gain from
what comes out of the FE)?
Yes you must be right. The output stage is just an input buffer with a current gain, not voltage so the only way to get more out of this is to increase the output of the gain stage. Increasing the value of R13 does increase the sensitivity but the gain stage still clips at 44v. I will attempt with the Bride of Zen pre-amp instead unless anyone has other ideas?
You mentioned you're building the single-ended version and that the amp
is clipping. Is it the output stage that is clipping? Do you have enough
bias there to support the higher voltage swing you want?
Hi Dennis.
The gain board is clipping at 44v p2p and this is reflected by the output boards too. The output stages are all followers, so they only swing what the front end does, and I have +/-24V supplies on the front end, so that sets the limit.
I think if the gain board was giving a stronger signal to the output boards, the output boards would probably cope.
no need, what is important is that you at last said that FE is using +/-24V rails .......... and it's completely logical that you can't have swing higher than rails so , 44-46Vpp is normal you can have more only if you cascode input stage and use higher rails
