Best sounding tube for low power?
Amplifier for headphones. A lot of time I devoted to studying the question - which valves are best for sound from low-power. I found next 2 favorits: PX4 Marconi-Osram 1 generation with barium anode (1920s) Sonatron 71a (171-A). Any body hear this tubes? Are there any better ones? Thanks. Best wishes.
The first thing you must do is decide what parameters you require as that alone determines the amount of distortion produced by the choice of valve.
The size of valve, anode area/cathode material determines the amount of power that can be produced and other parameters.
So, there is no best sounding valve.
Agree.
On this moment definitely i thick only - output power 0.1-1 watts, and impendance 32-42 Ohm.
Other parameters - too width range of conditions.
Just best sound.
Thanks!
Great!
I don`t hear earlier about 1626 and VT-137.
How about trode connected 4P1L? Can do a single per side or parallel them as needed. Triode connected 6P15P will also come very close.
Hard to beat a triode connected 6V6 too.
Or, if you don't have to be SE, a nice little 6SN7 push-pull?
Actually, yes it will. It can swing 40mA into the load which is only 50mW into 32R though. Still, 50mW is plenty for sensitive cans. My main set is actually 470R though so it'll push 750mW into them!
I have some datasheets for the -ER suffix type which states 330 V for both anode and screen.
Also, 65 mA cathode current max, which is useful since most of the other datasheets just give a pulse current max. Maybe needs a bit of derating since the -ER has a slightly (800 mA) more powerful heater.
