Digione signature is released:
DigiOne Signature Clean Power SPDIF Out
@cdsgames:
1) Have you sent out some samples of Digione signature for testers like you did with Katana so that we can expect some reviews to come up sooner or later?
2) If I have a modded RPi with the onboard regulator removed and which gets fed with three separate voltages (5V, 3.3V, 1.8V) in how far will I still have to feed the "dirty" side of Digione signature? Or will I simply have move the 5V connector from RPi into the "dirty" inlet of Digione signature and leave 3.3V and 1.8V connected directly to RPi just as before?
Best regards
Stefan
@cdsgames:
Best regards
Stefan
You need to feed the dirty side of DigiOne as this is where it gets 5V for the WM8805
If feeding 5V into the dirty side of Digione is mandatory, does it mean I cannot feed the RPi separately with threefold voltages as described above at the same time?
@cdsgames:
Will a USBridge Signature be launched as well?
Matt
Yes you can a diode is present after the dirty side.
@cdsgames:
Matt
No comments..yet.
No comments..yet.
It is a pity for all who have a DAC with USB input only.
Matt
- Digital Line Level
- DigiOne RCA/BNC output for RPI
