Shure stepped attenuator: why these values?
I'm looking at the schematic for a Shure FP11, a small battery powered mic pre:
Shure Publications | FP11
The gain control is a stepped series attenuator in the feedback loop of the first opamp, with an 84dB range in 6dB increments. Can anyone explain why R5-18, the series resistors, have the values they do? In order from R5 to R18:
1.33k (+78)
2.87k (+72)
6.65k (+66)
14.7k (+60)
15k (+54)
4.12k (+48)
1.33k (+42)
536 (+36)
237 (+30)
115 (+24)
54.9 (+18)
28 (+12)
14 (+6)
6.81 (+0)
The intervals don't make any sense to me---they rise and fall, with the highest value in the middle of the dial at +54. Any idea what I'm missing?
Thanks,
-Erik
Erik,
I noticed that the gain switching network also attenuates the stage output level. I was intrigued enough to simulate it. The given R values are correct and the overall stage gain does indeed track with 6dB gain steps, quite accurately within about 0.2dB worst case.
Thanks for posting the schematic,
Simon
PRR
Joined 2003
...Shure FP11 ...The intervals don't make any sense to me---they rise and fall, with the highest value in the middle...
It is a Gain AND Loss network.
The two ends of the resistor string do different things.
We sometimes see this in g-amps, which may need high gain and low. It is commonly implemented as a potentiometer. Common taper pots would not give a smooth taper over more than 30-40dB but that's ample for guitar. Shure not only wanted repeatable settings, they wanted 78dB of range, and the resistor string does that.
U2 is a (selected) LM386. R23 is surely 10r, not 10K.
One more question: What would be necessary to adapt this for use in another opamp circuit? Like, are there values (R4, R19, resistor string values, etc.) that are dependent on other values in the circuit, and would have to be changed? Or could you drop this on the feedback loop/output of most similar (noninverting amplifier-connected) opamps and get an 84dB attenuator?
The main feedback and attenuation resistors could be used in other circuits.
Don't forget R20, it's the upper half of the output attenuator. Because of R20, the output impedance is rather high so any following stage must be high impedance input or use a buffer. Also R3 is part of the feedback network.
Yes, as above, but you won't get 84dB gain from this stage alone. The U1A stage has just under 30dB gain on its own.
The rest of the gain comes from:
- mic input transformer, 20dB
- Output amp U2, 26dB
- Line output transformer, about 10dB
There's some other small losses to bring the total down to 84dB.
Here's the sim file
  • FP11 switched gain.zip
