What impedance are your Headphones?
What impedance your major headphones?
  • 8 Ohm
    Votes: 7 3.4%
  • 16 Ohm
    Votes: 23 11.2%
  • 32 Ohm
    Votes: 83 40.3%
  • 64 Ohm
    Votes: 41 19.9%
  • 100 Ohm
    Votes: 11 5.3%
  • 300 Ohm
    Votes: 70 34.0%
  • 600 Ohm
    Votes: 33 16.0%
  • Total voters
    206
HP comes in a big difference of impedances.
I like to know what impedance your headphones are.
The phones you consider as your major.
For myself I have phones with 32 Ohms.
Many earphones are 16 Ohms.
Sennheiser have 300 Ohms phones.
I've had 4 Ohms, 2Kohms, and higher.
In long-gone days my go-to was a 300r pair, but today 16-100 is much more common.
Why do you want to know? Are you going to individual-design an amp for each of us?
Unless you get the Pope to marry you and a headphone, you *may* like another set of different impedance at some later time. I don't see a future in a specific-impedance design.
Senn hd650: 300r
Senn hd25-13: 600r
The 600r impedance of the senn hd25 is actually a very, very nice point. As they are quite efficient, they still can be driven from a phone for example. But due to their high impedance, they require very little current, so they don't load the phone output much. It also means that their frequency response doesn't change much due to the output impedance of the phone. And, finally, since they still require a bit more voltage, they can used with the digital volume control way up, which is best. Great portable headphones.
Sony MDR 32 Ohm
CX 300 II 16 ohm
HD650 300 Ohm
Sony's are louder on a mobile phone or anything with a 3.3Vbattery, or IC.
Sennheisers take the voltage way better on a desk output.
I've still to try the CX out but they're sensitive and I may get away with it....Just.
I'd think 600 Ohm and beyond (inc joker JCX ESL phones) just takes the demandstoo far into the voltage domain.
Besides with low voltage computing (my term for anything 3.3vdc) well unless you have incredible sensitivity then you need current, there just isn't the voltage headroom.
Fidelity x2 32
K712 62
Dt770 pro 600
The k712 are my most used headphones. The DT770s need some juice to play loud but since they’re closed you can mostly get away with pretty low volume on them. I just don’t find them comfortable for very long...
More than one phone
I have more than one headphone, but cannot vote more than once.
Sennheiser HD-598, 50 Ohms.
Sennheiser HD-600, 300 Ohms.
Sennheiser PXC-250, 300 Ohms.
Superex PDP-79E Electrostatic, 4 Ohms resistance + stepup transformer, connected to power amplifier speaker output directly.
Many solid state headphone amplifier have high damping factor to drive 16 to 600 Ohms properly. You will need a good current capacity for low impedance, low efficiency phones. Exact phone impedance value is less important.
If you design tube headamp, you will need multiple tabs for the output transformer to match different impedance.
High output impedance receiver/power amp headphone jack or output transformerless tube amplifier present poor damping factor and may not work very well.
Majority of guys have 32 Ohm like me.
Then comes 300 Ohm and 64 Ohm.
When I design headphones amplifier I design first type for 8-64 Ohm.
The second type of amplifier fits from 100 to 600 Ohm.
It is a big difference if you have 32 Ohm or 600 Ohm.
Because of that you should make a different amplifier to suit each type of headphone.
