Aleph J illustrated build guide
all audio gnd wires in system must be connected to one point (on PSU pcb) only
I see from last pic (#2691) gnds (lilac wires) are going from two different terminal blocks
no good
from same point , wire to NTC , then to chassis
is it possible to find mid point for GND , between these two terminal blocks ?
I'm asking because I'm not familiar with these (Store?) PSU pcbs ......
no good
....ok I see...
6L6 did the same on the build guide for the PSU board!
.....I can use the two spade connections.....this would be the mid point!
Yes it’s the DIY Audio store PSU board
I have used the diyAudio ps board, although not in an Aleph J, and I used one block for all grounds and I connected the two blocks together with a short heavy gauge wire.
I see that there are empty pads at the ground of both sides of the supply. It wouldn't hurt to connect the two sides together with more wires to the empty pads.
Hum stays.....
It took me a while to return to my audio projects.
I tried quite a lot; tied all grounds together trying diffrent connections; both spade ground connectors and both ground screw terminals and connected the spade grounds with a heavy gauge wire;shorted shield wire of the transformer.
Hum stays....😕
But only on right channel,if I’m using my passive preamp which has no common ground for left and right channel.....
Hooked up to my ldr preamp(which has common ground) hum is on both channels.
So it should be a problem of the right channel!?
Any suggestions what I can do?
Besides th hum the amp is sounding great!
Gregor
it is very important where on pcb is main GND point - point where you don't have any pulsating current
I can't see that you took GND takeout to both pcbs from same point as 6L6 did
take a good look again at his build , and see if there is any difference
as I see it , he took GND from centrally placed lugs ....... where centraly is crucial ..... and he took GND wires from same lug
No real difference between spadelugs and the terminal blocks. All is similar, particularly if there are good connections between both sides of ground. (and his build has enough)
I used spade in that particular build only to try it and illustrate that it could be used.
OK
some tiresome tests:
- what's happening when just left channel is connected to PSU , with open RCA , shorted RCA and fed from preamp?
- what's happening when just right channel is connected to PSU , with open RCA , shorted RCA and fed from preamp?
in both cases "happening" means - what you hear in speaker ? do not forget to power off while messing with input RCA connections
Hum stays....😕
Gregor
when troubleshooting any problem, the process of elimination is the best approach. try a different pre-amp, different a/c plug, different amp, different input (tuner, cd, phono, etc.), etc. etc. etc. once the defective device is discovered, you repeat the same within the device.
you don't seem to have followed this or have not indicated that you have followed this.
again, my 2cents.
To answer the tests first
OK
...slight hum
, shorted RCA
......dead quiet
.......nearly quiet
......slight hum
, shorted RCA
....dead quiet
.....INCREDIBLE LOUD BUZZ 😱.....AFRAID I‘VE BLOWN MY SPEAKER
