FAOW
Lovoltech FAOW
Here's a go:
One watt only.
This has been cooking on the bench all day without issues.
12V switcher PSU and battery tested.
Regular 'ol "big" TO-220 heat sink and clip for cooling. Easiest heat sinking ever.
R2 will need to be adjusted (3-5 ohms) according to the Vgs of your JFETs.
Sweet spot around 9 to 9.5V Vds, .55A Id (ish)
THD <.4% @ 1W, Noise <400uV even with the laptop supply
Want a cute little PCB for easy assembly and mounting?
Is that bench nasty enough for ya? 🙂
Here's a go:
One watt only.
What is the name of the distortion meter you use to show THD etc.?
There are many step-up switchers. Just pick one.
I used LT3751 before, but there are also lower cost solutions.
Just google.
> Could P1 replaced by CCS?
No. And you should replace by fixed resistor once value is determined for 70mA bias.
And if you want both channel to have the same gain, you should match your FETs, so that the source resistor is the same.
Patrick
I´ve asking last year Pete to do LTSPICE simulation with WE transformer (easy available in Germany) based on his 10W flyback version. He does this and suggested to use the mentionned WE transformer and to switch to LT1170 (5A) to increase the power. Don´t forget, the supply capability is up to 325V@30W.
10V B+ Flyback Supply
Again many thanks to Pete.
JP
