The graph is unusual too (I have never simulated anything that has zero features before)
Not to burst your bubble too much, but THD is one of those things that is often not covered well in the simulation models. Your sim shows that you didn't make any obvious mistakes. I highly doubt measurements of the circuit will come even remotely close to the simulated values.
Regardless, it should still be a pretty nice amp. Watch the power dissipation in those itty-bitty packages, though.
Tom
Here is an interesting surprise, I replaced the LME47720, the supposedly "king of the low THD" opamps in TI's arsenal, with the lowly OPA1688 (which is also serving as the buffer).
Simulations of THD, while using only basic functional opamp models, make no sense. It will not produce any meaningful result. Those models are made from a bunch of controlled voltage and current sources. The only nonlinear effect they usually take into account is supply rail clipping.
There are transistor level models of opamps, but the one you have is not one of them.
For comparison, somewhat similar nested feedback circuit perfomance:
OPA1611 "The Crocodile"
vs
OPA172 - "The Crocodile"
LME49720 is a bit more nonlinear in those conditions compare to OPA1661, but not by a huge lot.
I know it will never measure like that, but wonder what is in the model then as it is from TI, and is revision B dated July 5, 2018 (a few weeks old), and with 8 in parallel the sim takes a lot of time.
You can open a model in a text editor and have a look what it contains.
Some models have an input stage "made of" transistors, to model noises and other effects associated with an input, and the rest of it made with controlled sources.
The fact that it runs a low does not say a lot. It may be happening because something makes spice to use very small timestep and not because if complexity of a model.
Here is the OPA1688 model from TI. The following are modeled (see bold below) - seems quite comprehensive to me
* OPEN-LOOP GAIN AND PHASE VS. FREQUENCY WITH RL, CL EFFECTS (Aol)
* UNITY GAIN BANDWIDTH (GBW)
* INPUT COMMON-MODE REJECTION RATIO VS. FREQUENCY (CMRR)
* POWER SUPPLY REJECTION RATIO VS. FREQUENCY (PSRR)
* DIFFERENTIAL INPUT IMPEDANCE (Zid)
* COMMON-MODE INPUT IMPEDANCE (Zic)
* OPEN-LOOP OUTPUT IMPEDANCE VS. FREQUENCY (Zo)
* OUTPUT CURRENT THROUGH THE SUPPLY (Iout)
* INPUT VOLTAGE NOISE DENSITY VS. FREQUENCY (en)
* INPUT CURRENT NOISE DENSITY VS. FREQUENCY (in)
* OUTPUT VOLTAGE SWING vs. OUTPUT CURRENT (Vo)
* SHORT-CIRCUIT OUTPUT CURRENT (Isc)
* QUIESCENT CURRENT (Iq)
* SETTLING TIME VS. CAPACITIVE LOAD (ts)
* SLEW RATE (SR)
* SMALL SIGNAL OVERSHOOT VS. CAPACITIVE LOAD
* LARGE SIGNAL RESPONSE
* OVERLOAD RECOVERY TIME (tor)
* INPUT BIAS CURRENT (Ib)
* INPUT OFFSET CURRENT (Ios)
* INPUT OFFSET VOLTAGE (Vos)
* INPUT COMMON-MODE VOLTAGE RANGE (Vcm)
* INPUT OFFSET VOLTAGE VS. INPUT COMMON-MODE VOLTAGE (Vos vs. Vcm)
* INPUT/OUTPUT ESD CELLS (ESDin, ESDout)
Code:
* OPA1688
* (C) Copyright 2018 Texas Instruments Incorporated. All rights reserved.
** This model is designed as an aid for customers of Texas Instruments.
** TI and its licensors and suppliers make no warranties, either expressed
** or implied, with respect to this model, including the warranties of
** merchantability or fitness for a particular purpose. The model is
** provided solely on an "as is" basis. The entire risk as to its quality
** and performance is with the customer
* This model is subject to change without notice. Texas Instruments
* Incorporated is not responsible for updating this model.
** Released by: Online Design Tools, Texas Instruments Inc.
* Part: OPA1688
* Date: 03JUL2018
* Model Type: Generic (suitable for all analysis types)
* EVM Order Number: N/A
* EVM Users Guide: N/A
* Datasheet: SBOS724 –SEPTEMBER 2015
* Created with Green-Williams-Lis Op Amp Macro-model Architecture
* Model Version: Final 1.0
* Final 1.0
* Release to Web.
* Model Usage Notes:
* 1. The following parameters are modeled:
* SLEW RATE (SR)
* 2. Model represent the device operating at room temperature only. No temperature dependency is modeled
.subckt OPA1688 IN+ IN- VCC VEE OUT
.model BB_SW VSWITCH(Ron=50 Roff=1e12 Von=700e-3 Voff=0)
.model ESD_SW VSWITCH(Ron=50 Roff=1e12 Von=250e-3 Voff=0)
.model OL_SW VSWITCH(Ron=1e-3 Roff=1e9 Von=900e-3 Voff=800e-3)
.model OR_SW VSWITCH(Ron=10e-3 Roff=1e9 Von=10e-3 Voff=0)
.model R_NOISELESS RES(T_ABS=-273.15)
V_ORn 33 VCLP -1.642
V_ORp 34 VCLP 1.65
V_OS 39 40 214.2U
V4 ZO_OUT_J1 OUT 0
V_GRp 53 MID 175
V_GRn 54 MID -175
V_ISCp 49 MID 74.98
V_ISCn 50 MID -75.98
V11 44 48 0
V12 43 47 0
VCM_MIN 67 VEE_B -100M
VCM_MAX 68 VCC_B -2
I_Q VCC VEE 1.6M
I_OS ESDn MID 7P
I_B 40 MID 10P
XU3 OUT_21 VEE_B MID PSRR_CMRR_0
XIn11 ESDn MID FEMT_0
XCLAW_SRC 22 23 CLAW_CLAMP MID VCCS_LIM_3_0
XU1 Zo_Cleft CL_CLAMP Zo_Cright MID ZO_OUT_J1 AOL_INN_J1 AOL_INP_J1 CLAMP
+ CLAW_CLAMP VSENSE AOL_ZO_0
XU5 VEE VCC ESDn ESDp ESD_0
C_DIFF ESDp ESDn 7P
S7 VEE OUT VEE OUT S_VSWITCH_1
S6 OUT VCC OUT VCC S_VSWITCH_2
XU4 OUT_J1_29 ESDp MID PSRR_CMRR_1
XU2 OUT_J1_30 VCC_B MID PSRR_CMRR_2
XGR_SRC 31 32 CLAMP MID VCCS_LIM_GR_0
XCL_SRC 35 36 CL_CLAMP MID VCCS_LIM_4_0
XCLAWp VIMON MID 37 VCC_B VCCS_LIM_CLAW+_0
XCLAWn MID VIMON VEE_B 38 VCCS_LIM_CLAW-_0
Xe_n 40 ESDp VNSE_0
Xi_np MID 40 FEMT_0
H2 41 MID V11 -1
H3 42 MID V12 1
S1 Zo_Cleft Zo_Cright SW_OL MID S_VSWITCH_3
SOR_SWp CLAMP 43 CLAMP 43 S_VSWITCH_4
SOR_SWn 44 CLAMP 44 CLAMP S_VSWITCH_5
C_CMn ESDn MID 1.5P
C_CMp MID ESDp 1.5P
C28 45 MID 1P
R77 42 45 R_NOISELESS 100
C27 46 MID 1P
R76 41 46 R_NOISELESS 100
R75 MID 47 R_NOISELESS 1
GVCCS8 47 MID 34 MID -1
R74 48 MID R_NOISELESS 1
GVCCS7 48 MID 33 MID -1
XIQPos VIMON MID MID VCC VCCS_LIMIT_IQ_0
XIQNeg MID VIMON VEE MID VCCS_LIMIT_IQ_0
XCL_AMP 49 50 VIMON MID 51 52 CLAMP_AMP_LO_0_0
XGR_AMP 53 54 55 MID 56 57 CLAMP_AMP_HI_0
R39 53 MID R_NOISELESS 1T
R37 54 MID R_NOISELESS 1T
R42 VSENSE 55 R_NOISELESS 1M
C19 55 MID 1F
R38 56 MID R_NOISELESS 1
R36 MID 57 R_NOISELESS 1
R40 56 31 R_NOISELESS 1M
R41 57 32 R_NOISELESS 1M
C17 31 MID 1F
C18 MID 32 1F
R21 51 MID R_NOISELESS 1
R20 MID 52 R_NOISELESS 1
R29 51 35 R_NOISELESS 1M
R30 52 36 R_NOISELESS 1M
C9 35 MID 1F
C8 MID 36 1F
R22 49 MID R_NOISELESS 1T
R19 MID 50 R_NOISELESS 1T
R12 37 VCC_B R_NOISELESS 1K
R16 37 58 R_NOISELESS 1M
R13 VEE_B 38 R_NOISELESS 1K
R17 59 38 R_NOISELESS 1M
C6 59 MID 0.1p
C5 MID 58 0.1p
G2 VCC_CLP MID 58 MID -1M
R15 VCC_CLP MID R_NOISELESS 1K
G3 VEE_CLP MID 59 MID -1M
R14 MID VEE_CLP R_NOISELESS 1K
XCLAW_AMP VCC_CLP VEE_CLP VOUT_S MID 60 61 CLAMP_AMP_LO_0
R26 VCC_CLP MID R_NOISELESS 1T
R23 VEE_CLP MID R_NOISELESS 1T
R25 60 MID R_NOISELESS 1
R24 MID 61 R_NOISELESS 1
R27 60 22 R_NOISELESS 1M
R28 61 23 R_NOISELESS 1M
C11 22 MID 1F
C10 MID 23 1F
C12 SW_OL MID 100P
R32 62 SW_OL R_NOISELESS 100
R31 62 MID R_NOISELESS 1
XOL_SENSE MID 62 46 45 OL_SENSE_0
H1 63 MID V4 1K
R11 MID 64 R_NOISELESS 1T
R18 64 VOUT_S R_NOISELESS 100
C7 VOUT_S MID 1N
E2 64 MID OUT MID 1
C13 VIMON MID 1N
R33 63 VIMON R_NOISELESS 100
R10 MID 63 R_NOISELESS 1T
R47 65 VCLP R_NOISELESS 100
C24 VCLP MID 100P
E4 65 MID CL_CLAMP MID 1
C4 AOL_INP_J1 MID 1F
R9 AOL_INP_J1 66 R_NOISELESS 1M
R7 MID 67 R_NOISELESS 1T
R6 68 MID R_NOISELESS 1T
R8 MID 66 R_NOISELESS 1
XVCM_CLAMP 69 MID 66 MID 68 67 VCCS_EXT_LIM_0
E1 MID 0 70 0 1
R89 VEE_B 0 R_NOISELESS 1
R5 71 VEE_B R_NOISELESS 1M
C3 71 0 1F
R60 70 71 R_NOISELESS 1MEG
C1 70 0 1
R3 70 0 R_NOISELESS 1T
R59 72 70 R_NOISELESS 1MEG
C2 72 0 1F
R4 VCC_B 72 R_NOISELESS 1M
R88 VCC_B 0 R_NOISELESS 1
G17 VEE_B 0 VEE 0 -1
G16 VCC_B 0 VCC 0 -1
R_PSR 73 69 R_NOISELESS 1K
G1 69 73 OUT_J1_30 OUT_21 -1M
R2 AOL_INN_J1 ESDn R_NOISELESS 1M
R1 73 74 R_NOISELESS 1M
R_CMR 39 74 R_NOISELESS 1K
G5 74 39 OUT_J1_29 MID -1M
R53 ESDn MID R_NOISELESS 1T
R52 MID ESDp R_NOISELESS 1T
R35 IN- ESDn R_NOISELESS 250
R34 IN+ ESDp R_NOISELESS 250
.MODEL S_VSWITCH_1 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.MODEL S_VSWITCH_2 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.MODEL S_VSWITCH_3 VSWITCH (RON=1M ROFF=1G VON=900M VOFF=800M)
.MODEL S_VSWITCH_4 VSWITCH (RON=10M ROFF=1G VON=10M VOFF=0)
.MODEL S_VSWITCH_5 VSWITCH (RON=10M ROFF=1G VON=10M VOFF=0)
.ENDS OPA1688
.SUBCKT PSRR_CMRR_0 psrr_in psrr_vccb psrr_mid
R80 psrr_mid psrr_in R_RES_1 10.6250124K
C27 psrr_in 4_75 166.45P
R79 4_75 psrr_in R_RES_2 100MEG
GVCCS8 4_75 psrr_mid psrr_vccb psrr_mid -9.4128M
R78 psrr_mid 4_75 R_RES_3 1
.MODEL R_RES_1 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_2 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_3 RES ( TCE=0 T_ABS=-273.15)
.ENDS
.SUBCKT AOL_ZO_0 ZO_CLEFT CL_CLAMP ZO_CRIGHT MID ZO_OUT AOL_INN AOL_INP CLAMP
+ CLAW_CLAMP VSENSE
R4_VS MID VSENSE R_RES_1 1K
GVCCS4_VS VSENSE MID CLAMP MID -1M
GVCCS4 79 MID 78 MID -1
C5 80 MID 16.422P
R11 78 80 R_RES_2 10K
R10 78 81 R_RES_3 3.2175909091MEG
R9 81 MID R_RES_4 1
GVCCS1 81 MID 82 MID -276.2764
C1 83 82 2.0527U
R3 82 MID R_RES_5 36.3271
R2 82 83 R_RES_6 10K
R1 83 MID R_RES_7 1
R1_2 84 MID 1
XVCCS_LIM_ZO 85 MID MID 84 VCCS_LIM_ZO_0
R11_2 85 MID R_RES_8 1.2502
C4_2 85 79 636.62F
R10_2 85 79 R_RES_9 10K
R9_2 79 MID R_RES_10 1
GVCCS1_1 83 MID ZO_CRIGHT MID -1.4474
C1_1 ZO_CLEFT ZO_CRIGHT 5.5583U
R2_1 ZO_CRIGHT MID R_RES_11 22.3514424K
R1_1 ZO_CRIGHT ZO_CLEFT R_RES_12 10K
Rdummy MID ZO_OUT R_RES_13 1K
Rx ZO_OUT 84 R_RES_14 10K
Rdc_1 ZO_CLEFT MID R_RES_15 1
G_Aol_Zo ZO_CLEFT MID CL_CLAMP ZO_OUT -89.0549
C3 86 87 144.7F
R12 87 MID R_RES_16 111.2
R8 87 86 R_RES_17 10K
R7 86 MID R_RES_18 1
GVCCS3 86 MID 88 MID -90.91
C2 89 88 159.2F
R6 88 MID R_RES_19 101
R5 88 89 R_RES_20 10K
R4 89 MID R_RES_21 1
GVCCS2 89 MID out2 MID -100
C2_A2 out2 MID 8F
R3_A2 MID out2 R_RES_22 1MEG
GVCCS3_A2 out2 MID VSENSE MID -1U
XVCCS_LIM_2 4_A0 MID MID CLAMP VCCS_LIM_2_0
C1_A0 CLAMP MID 40.5N
R4_A0 MID CLAMP R_RES_23 1MEG
R3_A0 MID 4_A0 R_RES_24 1MEG
XVCCS_LIM_1 AOL_INP AOL_INN MID 4_A0 VCCS_LIM_1_0
R4_CL MID CL_CLAMP R_RES_25 1K
GVCCS4_CL CL_CLAMP MID CLAW_CLAMP MID -1M
R4_CC MID CLAW_CLAMP R_RES_26 1K
GVCCS4_CC CLAW_CLAMP MID 87 MID -1M
.MODEL R_RES_4 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_5 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_6 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_7 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_8 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_9 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_10 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_11 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_12 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_13 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_14 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_15 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_16 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_17 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_18 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_19 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_20 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_21 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_22 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_23 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_24 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_25 RES ( TCE=0 T_ABS=-273.15)
.MODEL R_RES_26 RES ( TCE=0 T_ABS=-273.15)
.ENDS
.SUBCKT ESD_0 VEE VCC ESDn ESDp
SW5 ESDp ESDn ESDp ESDn S_VSWITCH_1
SW6 ESDn ESDp ESDn ESDp S_VSWITCH_2
SW1 VEE ESDp VEE ESDp S_VSWITCH_3
SW3 VEE ESDn VEE ESDn S_VSWITCH_4
SW4 ESDn VCC ESDn VCC S_VSWITCH_5
SW2 ESDp VCC ESDp VCC S_VSWITCH_6
.MODEL S_VSWITCH_1 VSWITCH (RON=50 ROFF=1T VON=700M VOFF=650M)
.MODEL S_VSWITCH_2 VSWITCH (RON=50 ROFF=1T VON=700M VOFF=650M)
.MODEL S_VSWITCH_3 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.MODEL S_VSWITCH_4 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.MODEL S_VSWITCH_5 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.MODEL S_VSWITCH_6 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.ENDS
.SUBCKT PSRR_CMRR_1 OUT IN MID
G_2 OUT MID 90 MID -250
R74 MID OUT R_RES_1 1
R2a MID 91 R_RES_2 100.1001001K
C1a 91 92 79.577F
R48 92 91 R_RES_3 100MEG
G_1 92 MID IN MID -1M
Rsrc MID 92 R_RES_4 1
R2b MID 90 R_RES_5 401.6064257K
C2a 90 93 39.789F
R73 93 90 R_RES_6 100MEG
GVCCS1 93 MID 91 MID -1
R49 MID 93 R_RES_7 1
.ENDS
.SUBCKT PSRR_CMRR_2 OUT IN MID
R80 MID OUT R_RES_1 2.5000625K
C27 OUT 4_94 3.1831P
R79 4_94 OUT R_RES_2 100MEG
GVCCS8 4_94 MID IN MID -40M
R78 MID 4_94 R_RES_3 1
.ENDS
.SUBCKT FEMT_0 1 2
.PARAM FLWF=0.001
.PARAM NLFF=1.8
.PARAM NVRF=1.8
.PARAM GLFF={PWR(FLWF,0.25)*NLFF/1164}
.PARAM RNVF={1.184*PWR(NVRF,2)}
.MODEL DVNF D KF={PWR(FLWF,0.5)/1E11} IS=1.0E-16
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVNF
D2 8 0 DVNF
E1 3 6 7 8 {GLFF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNVF}
R5 5 0 {RNVF}
R6 3 4 1E9
R7 4 0 1E9
G1 1 2 3 4 1E-6
.ENDS
.SUBCKT VCCS_LIM_3_0 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1
.PARAM IPOS = 10
.PARAM INEG = -10
G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)}
.ENDS
.SUBCKT VCCS_LIM_GR_0 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1
.PARAM IPOS = 100
.PARAM INEG = -100
.ENDS
.SUBCKT VCCS_LIM_4_0 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1
.PARAM IPOS = 20
.PARAM INEG = -20
.ENDS
.SUBCKT VCCS_LIM_CLAW+_0 VC+ VC- IOUT+ IOUT-
G1 IOUT+ IOUT- TABLE {ABS(V(VC+,VC-))} =
+(3.55E-15, 0)
+(10.0409, 0.0003165)
+(19.5806, 0.0006332)
+(39.9131, 0.0012661)
+(49.9586, 0.0016743)
+(60.011, 0.0022202)
+(66.47, 2.7E-3)
+(68.8242, 0.0030418)
+(72.6386, 0.004141)
+(74.9241, 0.0047363)
.ENDS
.SUBCKT VCCS_LIM_CLAW-_0 VC+ VC- IOUT+ IOUT-
+(0, 1.71E-05)
+(23.5589, 4.71E-05)
+(30.0752, 0.0003883)
+(40.1003, 0.0008738)
+(50.1253, 0.0014563)
+(59.6491, 0.0020874)
+(66.9173, 0.0026699)
+(70.1754, 0.0030583)
+(74.6867, 0.0040291)
+(75.9798, 0.0044175)
.ENDS
.SUBCKT VNSE_0 1 2
.PARAM FLW=0.1
.PARAM NLF=380
.PARAM NVR=6
.PARAM GLF={PWR(FLW,0.25)*NLF/1164}
.PARAM RNV={1.184*PWR(NVR,2)}
.MODEL DVN D KF={PWR(FLW,0.5)/1E11} IS=1.0E-16
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVN
D2 8 0 DVN
E1 3 6 7 8 {GLF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNV}
R5 5 0 {RNV}
R6 3 4 1E9
R7 4 0 1E9
E3 1 2 3 4 1
.ENDS
.SUBCKT VCCS_LIMIT_IQ_0 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1E-3
G1 IOUT- IOUT+ VALUE={IF( (V(VC+,VC-)<=0),0,GAIN*V(VC+,VC-) )}
.ENDS
.SUBCKT CLAMP_AMP_LO_0_0 VC+ VC- VIN COM VO+ VO-
.PARAM G=1
GVO+ COM VO+ VALUE = {IF(V(VIN,COM)>V(VC+,COM),((V(VIN,COM)-V(VC+,COM))*G),0)}
GVO- COM VO- VALUE = {IF(V(VIN,COM)<V(VC-,COM),((V(VC-,COM)-V(VIN,COM))*G),0)}
.ENDS
.SUBCKT CLAMP_AMP_HI_0 VC+ VC- VIN COM VO+ VO-
.PARAM G=10
.ENDS
.SUBCKT CLAMP_AMP_LO_0 VC+ VC- VIN COM VO+ VO-
.PARAM G=1
.ENDS
.SUBCKT OL_SENSE_0 COM SW+ OLN OLP
GSW+ COM SW+ VALUE = {IF((V(OLN,COM)>10E-3 | V(OLP,COM)>10E-3),1,0)}
.ENDS
.SUBCKT VCCS_EXT_LIM_0 VIN+ VIN- IOUT- IOUT+ VP+ VP-
.PARAM GAIN = 1
G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VIN+,VIN-),V(VP-,VIN-), V(VP+,VIN-))}
.ENDS
.SUBCKT VCCS_LIM_ZO_0 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 8000
.PARAM IPOS = 1300e3
.PARAM INEG = -1407.599e3
.ENDS
.SUBCKT VCCS_LIM_2_0 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 0.03675
.PARAM IPOS = 0.35
.PARAM INEG = -0.35
.ENDS
.SUBCKT VCCS_LIM_1_0 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1E-4
.PARAM IPOS = .5
.PARAM INEG = -.5
.ENDS
As i was saying, it does not contain a single transistor. Modeling distortion with this model useless.
There was no even need to go that far, it was obvious from spectrum you posted.
BTW, whatever it says this model covers in its headline is often far from being real. Yes, those header can lie 🙂
It appears to be a phenomenological model not a network of discrete actives. That doesn’t automatically make something “useless” - a company like TI with armies of engineers would probably not release useless models of their parts.
With Lser=0.15ohms for the PSU rails, the distortion sims are higher in THD and probably closer to reality. it really is sensitive to the series resistance of the power supply rails. The cases before were idealized ultralow ESR cases.
Here is 28Vpp into 50ohms with PSU Lser=0.15ohms:
FFT Components:
So it does respond to changes in circuit design and is not stuck at zero THD. Also note that the character of the HD is descending higher orders with dominant 2nd order, whereas the LME49720 has dominant 3rd order as shown in Post 1.
FFT Components:
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 1.000e+03 1.402e+01 1.000e+00 -0.04° 0.00°
2 2.000e+03 7.864e-06 5.609e-07 -178.42° -178.37°
3 3.000e+03 8.375e-09 5.974e-10 -5.85° -5.80°
4 4.000e+03 3.135e-06 2.236e-07 -176.02° -175.97°
5 5.000e+03 1.392e-08 9.926e-10 -3.43° -3.39°
6 6.000e+03 2.004e-06 1.430e-07 -173.77° -173.73°
7 7.000e+03 1.946e-08 1.388e-09 -2.37° -2.32°
8 8.000e+03 1.473e-06 1.051e-07 -171.53° -171.49°
9 9.000e+03 2.501e-08 1.784e-09 -1.75° -1.70°
Total Harmonic Distortion: 0.000063%(0.000000%)
First off, TI does not have "armies of engineers". When I worked there, we were all stretched pretty thin. Secondly, just because something is not "useless" does not mean that it is useful.
Models will always have their limitations. When you model something, you usually get to choose between having a model that fits broadly but isn't super precise, or a model that is very precise within a narrow operating range.
I think TI did pretty well in their modelling of the OPA1688 - at least judging by the feature list. All the important stuff is there: Small signal response, large signal response, loop gain/phase, etc. But you will also notice that THD is not on the list.
Your notion that "it takes a long time to simulate, therefore it must be a really good model" is laughable. The reason it takes a long time to simulate is most likely that the simulator has a hard time getting the simulation to converge on a DC solution so it can start the transient sim.
You've already shown the world that you have an amp that's probably not broken. Now do yourself a favour: Build it and measure it. Have a listen.
Tom
Tomchr,
Let’s not put words in my mouth.
You “quoted me” as saying:
Here’s what I actually said:
All I said that it took longer to run the sim with 8 vs 1 amp.
Don’t worry, I will build it and listen and measure it - like I always do. The the layout is getting wrapped up by JPS64 and we are finalizing the design of the DC-DC converter and LDO regulators.
But I get it, the sim is probably way optimistic and I know this is not going to measure anything close to PPB distortion - my equipment for one (the source and the ADC are limited consumer stuffnot an AP pro instrument).
”it takes a long time to simulate, therefore it must be a really good model”
I think you're conveniently taking your quotes out of context. Shaq888 noted that the models are made from "a bunch of controlled voltage and current sources". To which you replied with the release information and the fact that running a sim with eight opamps takes longer than a sim with one opamp. Both are valid statements but do nothing to address the fundamental fact, that Shaq888 and I are pointing out: That THD is not covered by the model. You can see that in the models you posted.
I'm sure AP will be happy to sell to you. If you aren't quite ready to buy your own, I do offer testing services at quite reasonable prices. 😉
Tom
Tom
Modeling opamp thd using model build only using controlled sources is useless, period. Results will have nothing to do with the reality.
I'm sorry I've broken your virtual zero thd dream, but your simulation results are misleading and give a wrong idea to others.
Now as for measuring those distortions. It is not as hard as it seems, it just takes some time to get started.
Actually, I am not a low THD dreamer at all. If you have seen my amps and designs - almost always strive for good harmonic profile and THD happens to be in 0.05% to 0.005% range and it sounds great. So not a big deal if the THD is not ultralow. It might be pretty low given the simple design vs more complex designs. We will see once built though.
What are you saying, Sergey?
Other than saying that zero THD is your goal, you have not made a good argument that X is not correct. The final arbiter is a critical listening test. THD sells product, but the subjectives determine whether products are keepers. After all, SE triode amps give ridiculous THD figures, yet people love them.
HD
HD
I don't see a connection to what I was saying.
You're not alone.
Making design decisions regarding THD from a simulation which does not include THD makes no sense to me either.
Tom
HD
Again, absolutely no connection to what I was saying. If you want to continue a conversation with me, please read through all my previous posts.
You're not alone.
Tom
It is normal to make mistakes. Although a bit of a critical thinking could help to avoid this one.
Only design decision based on sim was to use 1688 for the voltage gain driver in order to get a 2nd harmonic dominant profile (wheres 49720 was third order dominant). And low ESR rail caps to get low distortion based on low Lser values in sims. So is the 1688 model not accurately showing relationship between PSU series resistance and distortion? I think the model of the 1688 does account for distortion. Lack of an explicit section on THD doesn’t mean it doesn’t model distortion arising from other non-linear effects as we can see when changing the Lseries or the load impedance.
Please show me an opamp model that explicitly accounts for THD and has “transistors” inside.
Saying that a Spice model of an opamp is useless because it doesn’t contain transistors is like saying a model of a transistor is useless because it doesn’t explicitly contain a section of N and P doping on valence electrons.
You have made your intent clear. You make an assumption: I do not wish a conversation at all. Your attitude is one sided and arrogant and I know all the arguments on both sides. YOUR critical thinking is important here; an open mind.
- Headphone Systems
- Cheap as Chips OPA1688 Low-THD Muscle Amp
