Any suggestion on a configuration that can be used for a 4-way system?
thanks
Two 2-way plates per side or a 3-way plate with a sub plate. The last setup can't be used with a digital source.
Unfortunately the bug with reset of custom sampling freq to 44.1 is not fixed...though Hypex acknolegded bug 2 months ago. I use imported measurements and it's painful to change sampling rate manually every time i switch between advanced\basic settings
And combobox for filter type is not rendered\when scrolling (win10).Unfortunately the bug with reset of custom sampling freq to 44.1 is not fixed...though Hypex acknolegded bug 2 months ago. I use imported measurements and it's painful to change sampling rate manually every time i switch between advanced\basic settings
Hopefully hardware is more stable 🙂 Waiting for it anxiosly 😀
both me and windows installer did not find uninstall file (shortcut incorrect, [Windows cannot find 'C:\Program Files (x86)\Hypex Software\Uninstall.exe'. Make sure you typed the name correctly, and then try again.) and nothing in hypex folder similar to uninstall. so i removed manually - same stuff. Bad rendering of scrollbox (I have 1.25 pixel rate btw) and sampling rate of imported impulse resets after i go to advanced and back normal 🙁(I don't have those bugs here (win7 or 10), maybe a complete de and reinstall?
What is 1.25 pixel rate??
Do you have a asio driver installed and selected in the tools-asio preferences?
Just in time delivery.
Downloaded the new file at 14:00, packaged Plate arrived at 15:00!
Unit looks good, a miracle everything is sooo small: DSP, reciever etc. 🙂
( detail) Photos?Just in time delivery.
Scale Factor 125% in Windows Display settings.
I can capture a small video if it will help to troubleshoot.
On a separate note - I found in HFD Manual that Fusion support bluetooth as input? Really? That would be nice!
Thanks.
Will check the scaling factor later.
No Bluethooth, it is just there for future extension.
Checked the scaling factor on my W10 machine, scroll box is working properly at 100, 125 and 150%. I think there is something odd going on with your display driver.
It can be anything. Maybe anti-aliasing is turned on or ofg, a different default font (or fontsize) is used or Windows is set to a non-native resolution. But using bad drivers is most common.
Recorded a small video for you Recordit: Record screencasts fast & free! with GIF Support!
And another one one small minor drawing glith as well Recordit: Record screencasts fast & free! with GIF Support!
SNR, THD+N seem comparable to DLCP.
Pricing is pretty good relative to DLCP, considering that this comes with Ncore Amp modules.
Hopefully the sound quality is great as well, like it is for Ncore and DLCP
Do you slide the bar with the left mouse button pressed?
Yes. Notice that actual selected value both times is not what was displayed when I clicked. Because it actually scrolled but not rendered properly.
Is the 253 module shipping soon?
Yes, will be shipped tomorrow or the day after.
- Class D
- The New Hypex Fusion Plate amps
