Retro Amp 50W Single Supply
A little more.
Not butik parts here.
I think the schematic (or pcb) said to keep those diodes in contact with the heatsink.
Congrats on getting the build ready to test Thimios! Always disappointing when the board doesn't sing from the start but hopefully it is a simple fix! Any chance of a top-down photo of the completed board?
Cheers
Tnank all of you for answers, diodes 2X1N4148 are here bacause this is instead Vbe multipl.
Close contact to heatsink required.
Maybe closer or inside to a drilled hole is better.
Yes Prasi! Eagle eye!!!
Jumper is under the board because putting this on the top affect caps position. This is first ver. PCB and Prasi will see something better in the future.
BTW i can't see any disadvantage using this way.
I will take some underboard pictures latter.
Tnanks again.
I feel that i find the problem now, i amn't near the workstation but as you can see on post#332 a npn symbol represents the 2N5401.
Due to 2N5401 unavailability i used MPSA42.
The Right is a PNP here.
I hope all other will be ok. now.
another observation: There is no need to instal R8 if you already have the trimmer(R8'). Once you finalize the bias, you can instal equivalent resistor in R8 position.
Hi Prasi, did you mean... do no instal the fix resistor, instal the trimer, adjust for the bias setting, remove trimer, measure for the value, instal a same value fixed resistor?
Finally what is the recommended bias setting?
Hi thimios, yes, fixed resistor after bias set. Mr. Mile recommended 20mA to 50mA bias somewhere on the thread.
regards
Prasi
Quickly i can say, yes this amplifier is honest, he just ask low budjet parts except..... For power supply!
That's why Apex recomment cap. mult.
Low very low PSSR. due to single inp. configuration.
In my first attempt hum was audible two rooms far!
Now is silent without cap. mult.
The rest latter.
In any case don't expect good measurments, like square
waves, good clipping e.t.c.
How this play?
I like it!
Isn't the best but it is honest.
Yes i like this safe, cheap, good playing retro.
The mistake was on my side when I put a npn symbol in place of a PNP in the schematic.
Take your time, no hurry in this.
Prasi
No Prasi it is my mistake,there isn't a NPN trans.with emitter connected to + supply!
This is a stupid mistake,always i repeat stupid mistakes.😡
BTW someone must delete schematic from post #332 to prevent troubles in the future.
