The M2 requires 15 biquads for the HF part and 17 for the LF part.We can check with development what is possible. How many biquads would you like to see?
and what about the FA503?
I should be one of the first one who ordered these as I was placing the order just a few minutes after they went online
Jan-Peter, have a question that I can't find in the docs anywhere:
Would the NCore modules in the FA123 (125 @ 4 ohm) be happy with a 2 ohm load? I've seen some threads here suggesting NCore are happy (happier?) with 2 ohm loads, but those threads were discussing modules with higher wattage.
Thanks!
Thanks!
Any updates to preliminary datasheet on Fusions?
https://www.diyclassd.com/img/upload/doc/plate_amp/FusionAmp_00xx.pdf
... and that is without room-specific EQThe M2 requires 15 biquads for the HF part and 17 for the LF part.
Also next week shipping.
Thanks!
Yes, they can run in 2 ohm. However there is a risk the current protection kicks in and if for a too long period too much power the thermal protection.
We will put this on the 'nice to have list'.
Is there an easy way to make a I2s connection and run the DLCP with MatLab or SigmaStudio?
Might be, I don't know, easy is not the same for everybody...😉
Unfortunately we cannot support this.
Thanks Jan-Peter. That sounds a lot more like a "safe to" rather than a "recommended to". I guess I won't try to push them that hard.
I have just purchased a phono pre amp (Schiit Mani) but just wondering if anyone has tried to use RIAA Eq with the Hypex DSP and if its possible to use the new Fusion amps as as a turnable pre-amp and avoid the use of a phono pre-amp. This will be the only use for the RCA connectors in the Fusion, so I'm not worried about the filters being applied to say a CD player or similar.
Just a thought, I have seen people implement it with MiniDSP, and lots of back and forth again about IIR and FIR, but keen to know if any Hypex fans know if its possible and also worthwhile.
Thanks again in advance.
The RIAA also provides for 40 to 70dB of gain, as well as impedance matching, so you’ll need to come up with a solution fot that.
Johan-Kr
Johan-Kr
Having read the manual (not more) and played around with the software, I'd say: yes, you can make one filter with the RIAA curve additional to the standard filters you will have (that form the main filter in use).
I expect the S/N of the ADC is good enough for the 20 dB loss. You will need a lineair amplifier to create a 2 V RMS line-in signal; from 0,2 mV MC it's gonna be 50-60 dB (mind allowing some overhead for overload).
Then . . you can have the turntable at line level on e.g. the analog RCA, and as soon as that is the only input, the forlter assigned to that input is sepelected, and presto, . . you have a seamless source strategy.
I think the nc400 was a good example of Hypex both being aware of and favorable to the DIY community.I really find Hypex policy in generell very dislikable ... they should be more aware of the big DIY community who buys their products and hence keep their business up to a certain extend. And we want such things!
When talking about DIY and being offtopic.. - a question to all of you Hypex knowers: for a big 3-way active system, would a pair of Hypex UCD2K (with Hypex SMPS3K) play nice with 2 big 21" RCF PA woofer together ? (1 amp + 1 woofer per side). Power is not a question, both are heavyweight league but can the UCD2K be called an audiophile-grade amplifier (for bass only) ?
It is definitely technically good enough, but audiophiles are more guided by old wive's tales, superstition and hearsay, rather than rational, technical thinking, so who knows...can the UCD2K be called an audiophile-grade amplifier (for bass only) ?
You will be surprised how good this combination will sound. There are several pro-audio applications what use with great success this combination. Customer feedback is excellent, very solid and low THD, low frequency reproduction.
sorry for going off topic, but does a low level DC on Hypex module inputs, deteriorate the module performance in the long run?
I think you just ensured that Real AudiophilesTM will look down on it 🙂
I don't think there are any particular long term effects, but at least the ncores are DC coupled, so any DC will show up, amplified, on the output.sorry for going off topic, but does a low level DC on Hypex module inputs, deteriorate the module performance in the long run?
Half bridge Class D amplifiers don't like DC at their input...but as the Fusion amp has a DSP this will be filtered out. However always be carefull with too much DC. Long time zero problem.
- Class D
- The New Hypex Fusion Plate amps
